Microwave Ovens Logo
A
Anonymous Posted on Jan 16, 2018
Sharp rv mz a074 wreo 2m214 magnetron
Where can I buy this part?
Glenn
Level 3:
Master:
  • Sharp Master 591 Answers
  • Posted on Jul 25, 2019
Glenn
Sharp Master
Level 3:
Master:
Answers
591
Questions
Helped
171616
Points
6976
1 Related Answer
VEKAT
Devabhakthuni Venkateswara Rao
  • 225 Answers
  • Posted on Oct 09, 2007
SOURCE: SHARP R-9H 10
first you check all high voltage section circuit and check magnetron .. check control unit also..
Goldstar MV-1526W Microwave Oven caught fire over the control panel. The fire was on the connection to the LG Magnetron 2M214 can it be fixed?
take it to a repair shop for a proper diagnosis but generally anything other than a fuse , it will be cheaper to get a new unit
Where can I find magnetron : RV-MZ A074 WREO for Microwave : R-9H20W
Your missing the number for me to assist you, its could be like 2M167B for something like that. More information please. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
I need a magnetron for a Brother MF3200 microwave oven
How did you get on with your search for a new Magnetron ??
I have one of these great little cookers, but the buttons on the control panel are "sticking" or only intermittently operating - have to press pause many times to get the machine to shut down. I might need a new control panel or at best the one fitted needs a good internal clean - have you stripped your mmachine down ??
WHERE CAN I FIND MAGNETRON IN SHARP R6210 MICROWAVE OVEN
get the RV- ..... part number off magetron itself. try google. if it's a older model micro, the part may be discontinued.
2answers
Does not heat anything . it turns on. the carousel turns
If its under warranty you can have it replaced, otherwise its more than likely the magnetron tube which would cost more than the microwave to fix. You would be better off buying a new one
Sharp R-1850A Mocrowave Convection - No power
Chances are if the internal fuse and magnetron thermostat are good, then you have a circuit board that needs repair.
You can probably find exploded views at the Sears parts site. If you find a bad thermostat, the best place to order Sharp parts is Tritronics.
We regularly repair these control panels for customers nationwide (RV owners & dealers, too) with our guaranteed $39.95 service.
Feel free to contact me directly for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SHARP R-9H 10
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
