Humidifiers Logo
A
Alice McKinney Posted on Jan 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my Aircare tower humififier flashing CF??
Russ Hill
Level 3:
  • Master 4,057 Answers
  • Posted on Jan 16, 2018
 Russ Hill
Master
Level 3:
Answers
4057
Questions
10
Helped
1177762
Points
12696
Clean filter, filter is blocked not letting the air flow through correctly, take the filter out and clean it with warm water and leave to dry before refitting, can use soak but not to much as can damage the filter threads. but warm water will do the job to remove the particles its picked up.
Jean DeLauche
Level 3:
  • Master 2,911 Answers
Jean DeLauche
Master
Level 3:
Answers
2911
Questions
Helped
975704
Points
13030
Hello, Alice -
If you do not have the owner's manual for your AirCare humidifier you may be ale to obtain a manual from the manufacturer, Essick Air.
This is the link to the Essick Air Contact Us web page:
https://www.essickair.com/customer-support
You can find the email address to send a request for a manual for your model of AirCare humidifier or call and talk with a Customer Service Representative.
Best wishes.
3answers
Contrary to the owner's manual, my Aircare (Valiant) Humidifier HD1409 appears to have four (4) fan settings: 1, 2, 3, and "A". Can anyone tell me what "A" setting does?
From what you've described, it seems that the "A" setting may be a special or additional mode of operation. It could be an "Auto" or "Adaptive" setting that adjusts the fan speed based on the humidity level in the room, or it could be a specific function designed for a certain type of room. I recommend checking the owner's manual or contacting the manufacturer directly to find out more information about the specific function of the "A" setting on your Aircare (Valiant) Humidifier HD1409.
Jan 23, 2023 • Humidifiers
What does F mean on aircare humidifier? what does CF mean?
Which model do you have? On the H12 and 696 series models, F indicates refill the humidifier; the reservoir bottle is out of water. The CF means check the filter/wick. Replace the wick if appropriate. The CF message will appear every 720 hours of run time for the humidifier. It will be reset when the unit is unplugged or loses power.
You can find the Owner's manual for many of the Aircare humidifiers on the product page. Start at https://aircareproducts.com/ Then look for your humidifier. The link to the owner's manual is just below the Add to Cart button on the right side of the page. Use the manual to identify the correct filter or wick for your humidifier.
I hope this helps.
Nov 16, 2018 • Humidifiers
2answers
I have an essick humidifier and it keeps flashing CF but it continues to run. What does the CF mean.
Check Filter Indicator The ability of any humidifier to efficiently supply humidity output relies heavily on the condition of the filter. As the filter loads with impurities it gradually loses its wicking capability. When this happens, moisture output is reduced and the humidifier has to work longer to satisfy the selected setting. This humidifier has a check filter reminder timed to appear after 720 hours of operation. When the Check Filter (CF) message is displayed, disconnect the power cord and check the condition of the filter. If a build-up of deposits or severe discoloration is evident replace the filter to restore maximum efficiency. The CF message is reset when the humidifier is plugged back in.
Dec 03, 2017 • Humidifiers
I have a DOUGLAS SONIC MIST humififier that is at least 6-8 years old and I need a new filter--do you have a replacement????
Fix does not sell parts, however, if you will type "e-bay" in to your search engine, ask the same questions, and you can buy what you want there.
Nov 06, 2015 • Humidifiers
6helpful
How do you reset the cf on essick humidifier
I just changed the filter and it started flashing CF. How do you reset this other than changing the filter?
2helpful
Have a MA0800, have changed the filter but can't clear the flashing CF display.
You have to unplug the unit from the electrical outlet. Just shutting it off won't clear the CF code.
Our machine is flashing CF. We've put a new filter in, but cannot get it to reset. Do you know how to reset the machine?
I have the MA0800 and I have a CF flashing on the display. How do I get rid of this code? If it requires a clean filter, then how do I reset this code once I have a clean filter?
Change the filter then unplug the unit from the electrical outlet and the code will be cleared. Just shutting the humidifier off won't clear the code, it has to be unplugged from the power to clear the flashing CF.
Top Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Humidifier Expert? Answer questions, earn points and help others
