Question about Crock Pots & Slow Cookers
How do i program the sandra by sandra lee crock pot. I want to set it to cook on high for 3 hours and then go to warm
Posted by Cathy Munoz on
5 Related Answers
Anonymous
  • 26 Answers
SOURCE: Rival Crock Pot (Smart Pot) 3845-3850/3855/3860
Yes you obtain one from the nearest service center in your area. And the answer to your second question.There should be someone there who can answer your question?
Oaky Spurs21
Posted on Jan 14, 2008
Anonymous
  • 12 Answers
SOURCE: Cooks too hot
It would SEEM that this pot has a nanufacturing problem, where the thermal switches, that actually cycle the unit off when it reaches a certain temperature, are faulty...right from the factory. Its common to get a run of faulty thermal units, and is often seen in Coffee Makers.
Posted on Jan 25, 2008
Anonymous
SOURCE: Crock Pot Lid
i need this too
Posted on Sep 29, 2008
Anonymous
SOURCE: I need a manual & cook book for the rival crock pot bbq pit
THIS IS WHERE YOU WILL FIND IT.
http://www.fenwayfaithful.com/stuph/BBQpit.pdf
Posted on Dec 08, 2008
Anonymous
SOURCE: RIVAL Crock Pot 3350 - Replacement of Cooking Pot
I need a new liner for my Rival smart pot. the crock bowl broke.
Posted on Dec 30, 2008
How do you work the pc crock pot
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. Quoted from manuals on line
http://www.manualsonline.com/support/other/slow-cooker/manual-2538852
Sep 07, 2017 | Crock Pots & Slow Cookers
Vegetables take hours to cook. Something wrong??
what do you have your setting on the crock pot for maybe you need a higher setting for them.
Mar 11, 2013 | Rival 38501 Smart Pot 5-Quart
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    Just been given crock pot with 3 settings can you explain them no manual came with pot
    It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
    http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
    (209k)
    Find the little blue print that says enter security code and then you can dounload the manual.
    The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
    1. Place food in stoneware according to recipe.
    2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
    indicating that the unit is plugged in, but not turned on.
    HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
    3. Push the Cook Time button to scroll through the timed cooking
    options. Push once and the 4 hour light will illuminate, twice and the
    6 hour light will come on, etc. Select the time based on the length of
    time indicated in the recipe. Two time options are usually given. The 4
    and 6 hour settings are the HIGH temperature setting and may be
    used when you want your food done quicker. The 8 and 10 hour
    settings correspond to the LOW temperature setting and is used for all
    day cooking. In addition your Smart-Pot™ can be set to the Warm
    Setting by scrolling through the timed cooking options until the warm
    light illuminates.
    NOTE: The Warm setting is for keeping already hot food warm. Do not use
    the warm setting to cook or reheat food.
    4. When the cooking time is completed, the Smart-Pot™ slow cooker will
    automatically shift to the Warm setting and the Warm light will come
    on. NOTE: We do not recommend using the Warm setting for more
    than 4 hours.
    5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
    wall outlet.
    6. For other recipes that give a range of times, select the time closest
    to the setting on your Smart-Pot™. For instance a recipe calling for
    cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
    NOTE: If power goes off then power light will blink and settings must be
    reset. If cook time is changed before the cycle is complete the time will
    reset to the new setting.
    Thanks for choosing FixYa,
    Kelly
    Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
    I need the user instructions for use
    Hi and welcome to FixYa, I am Kelly
    I see I am nearly a month late in replying to your post. I just answered another post and when I finished I saw your question.
    This is driectly from the user's manual that you can find here with some difficulty:
    (Avoid answering questions by looking for the blue text that says "security code" and clicking that) Then enter the 4 digit code to download the manual that is 209k)
    2. Plug in Smart-Pot slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on.
    3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot can be set to the Warm Setting by scrolling through the timed cooking options until the warm
    light illuminates.
    NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food.
    4. When the cooking time is completed, the Smart-Pot slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours.
    5. To turn the Smart-Pot off push the OFF button. Unplug unit from the wall outlet.
    6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot to 8 hours.
    NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will reset to the new setting.
    That is pretty much the entire user instructions. Everything else is warnings, cautions, and oh yes; don't submerge it in water yadda yadda....
    Kelly
    Feb 05, 2011 | Rival 38601 Smart Pot 6-Quart
    I need an owners manual for the SCVC651
    I couldn't find the specific manual for this, but I did find some basic instructions on a personal review:
    "Rival calls this a SmartPot and describes this unit as "programmable". All this really means is that you can program the slow cooker to cook either on "High" or "Low" for up to 20 hours, in 30 minute increments and then it will automatically switch to the "Keep Warm" setting and keep your meal warm for hours. You cannot program multiple steps, such as going from the "High" to the "Low" setting. The red, LCD clearly displays the remaining cook time.
    Simply plug in the slow cooker, and then push the clearly marked buttons (with a pleasant, audible tone) to move from "Low" to "High" to "Keep warm" settings. Then push the Timer Button to set the desired cook time."
    Hopefully, this helps answer your questions!
    Nov 23, 2010 | Rival SCVC651-F Slow Cooker
    Whats the differences with the low high and auto settings on a slow cooker which setting is considered best for cooking stews
    The difference is the time and how warm it cooks. Low cooks a slow, lower heat - cooks 6-8 hours. And High is a faster cook at 4-6 hours. I tend to use low for stews and chilis.
    Feb 11, 2010 | Crock Pots & Slow Cookers
    No manual for my old Crock Watcher by Proctor Silex
    The auto setting cooks on high for the first hour, then adjusts the setting to low for the remaining cooking time.
    Auto Shift allows the slow cooker to heat up to high and then internally shift down to low, so it gives more flexibility in cooking time. Example: A certain recipe may take 4 hours on high, 5-6 hours on Auto Shift and 7-8 hours on Low.
    Oct 19, 2009 | Crock Pots & Slow Cookers
    Need directions for presidents choice slow cooker
    Heat intensity is warm, 1, 2, 3 (highest)
    How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
    Apr 11, 2009 | Crock Pots & Slow Cookers
    Can't go straight to warm setting
    Hi, Guys,
    I discovered this solution by accident. To get my crock pot to go to the "Warm" setting directly, I begin by pressing and holding the "Cook Time" button. Then, with the cook time button held down, press and release the "Off" button, holding it down for a second or so and then releasing it. Finally, lift your finger off the "Cook Time" button. Presto! The unit will be set on "Warm." So the key to this is to press and release the "Off" button WHILE the "Cook Time" button is being held down. Might take a couple tries before you get it, but then you'll see that it works every time.
    Jan 27, 2008 | Rival 38501 Smart Pot 5-Quart
    Crock Pots & Slow Cookers Logo
    195 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    Tom Chichester
    ray gallant
    Andrew Taylor
    Andrew Taylor
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
