Https://rcaav.com/wp-content/uploads/2016/09/RCT6513W87DK-ebook_En-25-07-2016.pdf
click on this link or copy and paste it into your browser's address window read your owner's manual there or download the pdf into your computer. On page EN-29 you will find the solution press and hold the power button for eight seconds to reset
SOURCE: Model # rct6378w2 ... an rca tablet ... i cannot
Have you tried this? http://rcatablets.com/sites/default/files/Tablet%20recovery%20mode%20to%20wipe%20data%20Android%204.1.pdf
SOURCE: I forgot password on my RCA tablet. How can i reset it? I need a hard reset, how do I do that?
While it's turned off you hold the volume up and power buttons. Then when the android appears release the buttons. Hold the power button and press volume up. Navigate with the volume keys and select factory data reset. Hopefully this isn't the method you'd already tried.
You must then do a factory reset using the Power and Volume
Buttons.
Here is a good link that tells and shows how to do it:
http://www.rcatablets.com/how-completely-reset-your-rca-rct6103w46-android-422-tablet
The model number is not the same but it should work anyhow.
There is a typo in Step 1, however so do this instead:
With the tablet turned OFF (not sleep but OFF) press and hold down at the same time both the Volume(-) button and the Power button. Continue to hold both of them down until you get a screen with the Android Robot, and or green text. That should set you up to follow the instructions.
Good luck.
SOURCE: rca 10.1 tablet rct6303w87dk with 5.0 lollipop. How do I factory hard reset?
Follow the detailed instructions below on how to completely reset your RCA Android 5.0 tablet.
Applicable models: RCT6773W22B, RCT6203W46KC, RCT6213W87DK and RCT6303W87DK
Step 1. With your tablet off, press and hold the volume up (+) button and power button until you see the RCA splash screen with Nipper and Chipper. Release both buttons to reveal the Android bot on his back with a caution symbol above him.
Step 2. A new screen will appear asking you to use your volume up/down keys to move and the power button to select.
Step 3. Use the volume down (-) button to highlight "wipe data/factory reset." Once highlighted, select using the power button.
Step 4. A new screen will appear asking you to confirm your selection. Use your volume down (-) button to highlight "Yes -- delete all user data." Press the power button to select once highlighted.
Step 5. Once the tablet is finished wiping data, you may press the power button to select "reboot system now." This will restart your tablet.
Step 6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished. Congratulations, you have successfully reset your RCA 7 Voyager tablet.
How to completely reset your RCA Android 5 0 tablet
Generally speaking, whenever an electronic device cannot be accessed because of a password issue, about the only thing that you will be able to do is to either take it to a qualified tech to see about resolving the issue, or send it back to the factory for resetting.
In either case, you're probably going to be asked to provide some evidence of ownership, so be prepared for that.
Totally sorry that I couldn't assist you more. Good luck!
