SOURCE: how to easre memories of
1. Press the User-Select button to select User 1 or User 2.
2. Press and hold the button the that has a clock impression on it and the + button at the same tie while in the memory recall mode and the stored data for the selected user will be deleted automatically.
SOURCE: Homedics BPA-110-2AU blood pressure monitor.
This can be due to failure of the pump. If there is indication for the start of the pump , then the pump motor must be initiated . If not you will need to trace the power supply to the motor if not present the driver can be faulty. If present the motor drive is jammed or failed.
SOURCE: Can you clear all readings from monitor? I have
1. Press the User-Select Button to select User 1 or User 2.
2.
Press and hold the button that looks like it has a clock face on it and
the + buttons at the same time, while in the Memory Recall Mode and the
Hope this helps to answer your question. Please let me know.
SOURCE: i have a walgreens by homedics bpa-430wgn blood
CA means CALIBRATION required and you must send it in.
SOURCE: I Have a HoMedics Bpa
Sure, Roger. You can obtain a manual by calling HoMedics Customer Support 1-800-466-3342. They can supply you with a manual.
Hope this helped you and thanks for choosing FixYa.
