Question about Hotpoint Washing Machines
Hotpoint BHWD129/1 washer drier. I switch it on and after 10 seconds button lights start to flash the machine starts filling and filling until I switch it off. LEDs lit are the bottom 4 of 6.
Within the first 10 seconds I can set the programme to PUMP OUT and Start, and the machine starts to pump out water. It drains correctly until it goes into error state. If I turn off the water supply and switch it off and on I can do this again and again until the machine is empty. No matter what buttons I press and even if I press no buttons it will still go into error state after about 10 seconds. EDIT: for future reference, a technician came round, changed the heating element of the dryer and everything is working again.
Eric Sutherland
    Master:
  • 665 Answers
  • Anonymous Jan 15, 2018
    Thanks for the link, but it is to the product page for the unit. Am I looking for something specific here?
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: ariston washer
is this a new washer. if so remove shiping bolts from bottom or back.
Posted on Feb 16, 2008
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Posted on Oct 30, 2009
Anonymous
  • 4323 Answers
SOURCE: Set to any cleaning cycle, hit the start button
Hi
If you believe that the latch is fine then try to hear a hum like sound from the motor, also check that the motor is working fine as it that won't work the unit won't start the cycle. If everything else seems to be fine then it is the Timer that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 29, 2010
Anonymous
  • 122 Answers
SOURCE: Candy go 482/2 80 does
door switch or panel troubleshooting
Posted on Jul 02, 2011
Mr-Electro
Alain Vaillancourt
  • 120 Answers
SOURCE: no matter what programme i use the dryer only works for 20 minutes then switches off
more info please provide model number
Posted on Jan 07, 2015
Tip
How to Reset Your Water Filter Light
<b>Amana:<br /></b> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>auto light</b> buttons on the dispenser for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>water</b> buttons for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>After replacing the water filter, press and hold the Reset Filter pad for 3 seconds. The Order and Replace indicator lights will blink and then go off when the system is reset.</li></ol><span style="font-weight: bold;">Brita:</span><br /> <ol> <li>Press firmly and hold start button for 5 to 10 seconds.</li> <li>Four bars will appear in the display, one after the other, and flash. Do not release the start button until the 4 bars appear and start to flash. If you have difficulty pressing the start button, a capped ballpoint pen may be used to press the button down.</li> <li>A small flashing dot in the lower right corner shows the indicator is working.</li> <li>Every 2 weeks a bar automatically disappears. When only 1 bar remains make sure you have a new filter on hand.</li> <li>After 2 months, when all bars have disappeared, an arrow will flash at the top of the display reminding you to change your filter. </li></ol><b>Frigidaire<br /></b> <ol> <li>Press and hold the <b>reset </b>button on the dispenser until the green light flashes (up to 15 seconds).</li></ol><b>GE:<br /></b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol>or<br /> <ol> <li> Press the reset button on the dispenser for 4 to 8 seconds then release. </li></ol><b>Hotpoint:<br /> </b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol> <b>Jenn-Air:<br /> </b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol><b>Kenmore:<br /></b> <ol> <li>Press and hold the button next to the filter light for 10 seconds.</li></ol><b>KitchenAide</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol><b>LG:<br /> </b> <ol> <li>Press and hold the <b>reset</b> button for 3 seconds.</li></ol><b>Magic Chef</b> <br /> <ol> <li> Press and hold the light and lock pads until the change filter light flashes. (approximately 3 seconds)</li></ol> <b>Maytag:<br /></b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol>or<br /> <ol> <li>Press the refrigerator's light switch five times within ten seconds.</li></ol><b>Samsung:<br /> </b> <ol> <li>Press the <b>ice type</b> and <b>child lock</b> buttons simultaneously for 3 seconds. NOTE: Hold the buttons for only 3 seconds. If you press these 2 buttons simultaneously for 5 seconds, the reset function ceases.</li> <li>Release the buttons and repeat the same step one more time. The water filter indicator light should turn green.</li></ol>or<br /> <ol> <li><span>Press and hold the "Alarm/Hold" button for 3 seconds.</span></li></ol>or<br /> <ol> <li><span>Press and hold the <i>Fridge </i>and <i>Power Cool</i> buttons for 3 seconds.</span></li></ol><b>Whirlpool</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol>
on Jun 17, 2011 | Refrigerators
Lights flashing on Hotpoint BHWM129
I had a similar problem with my Hotpoint BHWM 129 washing machine. The washer would not spin or drain properly and all the lights flashed after a wash cycle.
The solution was to pull the washer out and UNBLOCK the drain pipe which was crushed AND filled with 'gunk'. Once the crushed pipe was massaged back to normal size and the gunk was removed my problem was fixed. Not a nice job but I was going to ring HOTPOINT at £125 a call out fee so I am happy. I hope this helps someone else in time.
Apr 30, 2012 | Hotpoint Washing Machines
Our Hotpoint Aquarius dishwasher initially had the Eco & Prewash lights flashing & standing water inside. We then turned it on in the hope that the standing water would drain, which it did. It then...
Is it a dishwasher a washing machine or a drier? Washing machines don't have rotating arms and you said "I've managed to get the drier to drain"
I will assume it is a dishwasher in which case it sounds like your pump has failed.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My Hotpoint Aquarius WF440 fills up fine but will not move on to rinse and spin. Engineer been out and says its the heating element. He has asked me to wash on no heat until part arrives. Since then every...
I am fairly confident that the problem is entirely due to the fact that the heater is not working.
You are going to have to wait until the new heater is fitted beore being able to tell if there is another fault.
Hope this helps.
Dec 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF645 error message: test
press start once then press again then hold on/off and cancel for a few seconds should now turn test off should be ok now
Jul 15, 2009 | Washing Machines
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
