Question about Tablets & eReaders
My proline tablet H71930i will not charge or be turned off. The indicator that the battery needs recharge when off does not show....please help it worked this morning but now it's dead.
I have checked that the charger works. The tablet charged last night and it was working this morning...
Posted by tanya buckton on
bozarthm
    New Friend:
  • 12 Answers
Do a hard reset and then make sure the software is up todate. 1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
Posted on Jan 15, 2018
5 Related Answers
Anonymous
  • 1187 Answers
SOURCE: Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Posted on Sep 03, 2009
SOURCE: my mid tablet will not charge
your charger probably died. go out and by a new one and see if that fixes your issue.
Posted on Apr 02, 2013
DaFixIsN
  • 183 Answers
SOURCE: I have an Asus Memo Pad HD 7 which I purchased 3
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Posted on Oct 30, 2013
Testimonial: "I did do a factory reset but the icon is still not showing and it still is slow at recharging. I didn't really have many programs anyway, a few simple card games, crossword puzzles and some weather apps. Right now, I think I have maybe 4 simple apps on the tablet and it is still not charging when on. I checked the battery status in settings and it says "not charging". However, if I turn it off and then plug it in, a red battery indicator shows it as charging."
jasonnashjlu
jason
SOURCE: Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Posted on Nov 09, 2013
Nuwan Chinthaka
  • 170 Answers
SOURCE: tablet wont turn on
Hi Leah.
if you plug it again is it indicate charging.
if yes it can be power button problem.
if not it can be softwear or hardwear error.
you have to repair it.
regards,
nuwan
Posted on Jan 10, 2014
Why does my tablet just show a red battery when I turn it on?
If it's a newer tablet it should be rechargeable. And a red battery light indicates the need for it to be charged. On one of the side edges of the tablet there should be a micro USB or other port for a charging chord to plug into.
2answers
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
My tablet saya charged but when I unplug it turns off
Perhaps only the rechargeable battery is on its end of life? or your charger is not capable to give enough power to charge the battery and drive the tablet at the same time.
If you only could charge the battery once , while it is not connected, that could give an indication of its condition, when you start using it.
Sure you are charging the tablet with an original charger? Like they delivered with the tablet?
Battery not charging tablet gets hot and wont turn on
The battery is dead and cannot be recharged. Replace the battery.
Forcd Factory Reset
best learn the principles of your tablet first
first when a battery is less than 10% it takes up to 5 hours to recharge not 5 minutes
next many tablets do not recharge when in operation so you have to shut down to allow the recharge to work
because the battery was dead flat , of course it will reset as that is the same as removing or installing a new battery
My Samsung galaxy tablet 7.0 died out while im playing a game, when I tried to recharge it a battery icon with caution sign show up. It does not recharge anymore. Tried another charger of my other Samsung...
Connection on tablet from charger to battery is not being made and that is why it is not charging in one unit but charging in other. Till problem is resolved charge battery in other working unit.
4helpful
Kaser Android tablet will not turn on or charge its brand new
Did you drain the battery completely and try to recharge it? A lot of people have problems if they drain the battery and recharge. I went through 3 A300 tablets before I figured out I had to recharge the tablet BEFORE it went dead or it would never start again. I don't know why but many brands have this problem. Also, do not shut it completely off when it is on the charger. Always take it off charge, or turn off before charging. I had another prestige that had to be replaced because I turned it off or on while charging. I have not found out why this happens to many tablets! Good luck!
Samsung battery wont charge need to reset it
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
