Question about LG Refrigerators
Where is the ice maker fan for LG French Door Refrigerator?
  • 166 Answers
The ice maker fan is located in the freezer and is part of the Grille Assembly ( LG part Name) Which is the removable back panel in the freezer. If you have an error code on the display such as ER/IF the fan is not rotating due to failure or ice accumulation in the fan blade. If you have no error code and the ice maker is not producing ice 2 things to check are...1. On the bottom of the ice maker there is a Test Button. Press and hold the button and the ice maker should rotate, Dump ice cubes and refill with water. If the ice maker does not cycle replace the ice maker. 2. Check freezer temperature. Freezer Temperature must be below 15 degrees to make ice. Ideally freezer temp should be 0 Degrees. If you have warm temps in the freezer there may be a sealed system issue preventing proper cooling.
Hope this helps.
Mike
Posted on Jan 21, 2018
5 Suggested Answers
Anonymous
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
Anonymous
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
Anonymous
  • 221 Answers
SOURCE: LG refrigerator french door icemaker not working
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jan 16, 2009
Anonymous
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Our 3 yr old LG Model LFC25760SW French door
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 26, 2009
Leaking and ice maker is not working
Your ice maker freezer fan may be iced up. Take the freezer bin out and look at the back of the freezer. If there is ice built up, you have to defrost it.
Jan 04, 2016 | LG LFX25960ST Stainless Steel French Door...
Ice maker fan running constantly
There are 3 fans on your refrigerator how are you sure that it's your ice fan that is running?
Nov 08, 2013 | LG LFX23961SW Bottom Freezer French Door...
If your ice maker is in the cabinet on the left side of the refrigerator the accellor fan is behind that cabinet.
Apr 14, 2013 | LG LFX31945ST Super Capacity 3 Door French...
LG french door refrigerator ice maker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 11, 2010 | LG LFC25770ST (250 cu ft) Bottom Freezer...
Tried to replace the filter and after that the upp
I don't think replacing the filter had anything to do with your problem.  If the ice maker is working then the freezer is OK since they have the same cooling source.  I had the same problem with this model refrigerator six months after I got it (in 2/2007).  The cooling in the refrigerator section failed.  The refrigerator fan and the air duct as well as the mother board were replaced.  A year later the ice-maker fan froze up. It and the housing were replaced with improved models.  The mother board was also replaced again due to software changes related to the ice maker.  This model is also part of an Energy Star/LG case agreement to modify the circuits and provide a lifetime annual rebate payment.  Check it out and register on the LG web site.
May 19, 2009 | LG LFX25960ST Stainless Steel French Door...
LG French Door Refrigerator 3 door - Smoke out of Door Panel
Take out the freezer bins and look at the very rear of the freezer compartment. This is where your ice maker fan is. If it is caked with ice you have to defrost it. It's a pain, but it fixed my problem.
Mar 15, 2017 | LG LFC21760 Bottom Freezer French Door...
LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
Sep 10, 2008 | Refrigerators
Refrigerators Logo
169 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
