Question about Yamaha Boating
Hi, can you tell me the year model of my Yamaha 40hp outboard? Serial number 452214.
Posted by Glenn Jones on
Andrew Taylor
    Top Expert:
  • Yamaha Master
  • 33,434 Answers
Search Results
Yamaha Outboard Serial Number Location and Model Identification ...
https://www.perfprotech.com/.../yamaha-outboards/yamaha-outboard-serial-number-l... The Yamaha Outboard Motor MODEL, PRE-FIX and SERIAL NUMBER are stamped on a plate attached to the transom clamp bracket. When ordering parts and/or accessories from our Yamaha OEM Online Parts Catalog it's important to properly identify the exact model you are dealing with.
Yamaha Year Models - Hunts Marine
https://www.huntsmarine.com.au/pages/yamaha-year-models This Yamaha outboard year model chart will only work for Asia Pacific distributed engines. If you have a Yamaha engine that has been bought in from America or E. ... For Asia Pacific engines your year model code is found on the bottom right hand corner of your serial number decal. It will be a single letter as per the ...
Decoding Yamaha Outboard Motor Model Number and Manufacture ...
www.murrayyachtsales.com/decoding-yamaha-outboard-motor-model-number-and-... Dec 30, 2015 - Decoding Yamaha Outboard Motor Model Number and Manufacture Date (MFG Date)
Yamaha Outboard Serial Number Lookup
uvgb.you4k.top/ By Darnell Zacharias. DOWNLOAD Yamaha 60HP (60 HP) Repair Manual 1984-2009 Outboards 8.8. By Michael Hornby. HOT. How To Decode A Suzuki Outboard Serial Number 8.4. By Ralap James. Mako 261 Center Console Boat For Sale at Unreserved Auction (Inv.3368) 7.1. By Aldrich Child. yamaha 40hp 2 stroke ...
Outboard Spares YAMAHA Model Year IDENTIFICATION CODES ' eBay
www.ebay.com/gds/Outboard-Spares-YAMAHA-Model-Year...CODES-/.../g.html Outboard Spares Yamaha Outboard Model Year Identification Details needed for ordering outboard spares parts On the Serial Number Plate on most Yamaha Outboards it will be in this format 6E9-L-675634 The...
Posted on Jan 15, 2018
5 Related Answers
Anonymous
SOURCE: Yamaha outboard engine
Procedure for carb. adjustment for 1992 Yamaha 30 h.p. 2 cycle outboard motor
Posted on Dec 30, 2008
Joe Hogan
  • 10865 Answers
SOURCE: What year model?
Call a yamaha dealer, ask for the service department. They will be able to tell you the model year.
Posted on Apr 09, 2009
mcgyver468
Mark L. Roberts Jr.
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
Anonymous
SOURCE: year model of yamaha outboard and fuel mix ratio
See linked manual!
JD
Manual
Posted on Sep 26, 2009
Anonymous
  • 4 Answers
SOURCE: HI SERIAL NUMBER ON MY V-STAR 1100 , CAN YOU TELL
If you look at the VIN number on the headset of the frame, the 9th digit is usually the last number of the year
Posted on Mar 03, 2010
What year is the serial no of my yamaha 200hp
if this is an outboard motor then try this website and see if you can get the information from it. good lusk.
Dec 12, 2017 | Miscellaneous
Serial no. 469271 70 h.p. yamaha outboard motor what year is it?
It is not possible to retriev a year on yamaha with only the serial number.
On the serial number sticker, you'll find other data, like type, length, horsepower, weight etc...
In the link I give you'll find all the needed data and you will be able to obtain a mfg year...
Posts Tagged Yamaha Outboard Serial Numbers
Oct 06, 2017 | Yamaha Boating
Year of manufacture of Johnson 40Hp outboard Model No AJ40BALE1A Serial No. G02651879
Ed,
Near as I can tell, it's a 1979. As of 1980, Johnson/Evinrude used two LETTERS at the end of the model number to designate the year. (See attached) Your model number ends in a number and letter (1A) which leads me to believe it's earlier than 1980. Prior to 1980, the last two numbers of the serial number were the year. That's how I surmised yours is a 1979, by the last two of the serial. G02651879
Hope this helps.
Fred-
Outboard Engine Serial Number Year Match up
Dec 05, 2016 | Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
What year and model is my antique evinrude motor?
I have never seen anyone answer these questions.if you looking for a condenser they are all the same.eg a 1965 40hp condenser will fit a 1955 20hp
Oct 01, 2014 | Sierra International 18-5199 Marine...
Mercury outboard s/n 9445826, what year was this motor built ?
call mercury outboard they can tell you the answer to your question
Aug 29, 2013 | Raymarine St6002 Smartpilot Hydraulic...
Boating Logo
742 people viewed this question
Top Yamaha Boating Experts
Colin Stickland
Colin Stickland
Mike
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
