Question about Locks & Locksmithing
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
Posted on Sep 07, 2007
SOURCE: no 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Posted on Jan 29, 2008
SOURCE: PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Posted on Mar 15, 2009
SOURCE: my renault laguna 1999 rt remote key fob wont work?
IF YOU TYPE 1999 RENAULT LAGUNA REPROGRAMME KEY INTO A GOOGLE SEARCH, YOU WILL BE ABLE TO PRINTOFF INSTRUCTIONS TO REPROGRAMME THE KEY TO THE KEY READER.THE IGNITION NEEDS TO BE OFF TO DO THIS
Posted on Dec 02, 2009
SOURCE: My cordless wave mouse not working red and green light goes mad.
i have the same problem
Posted on Jul 03, 2010
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Jan 09, 2011 | Safe International Electronic Digital Safe...
Dec 31, 2010 | Weiser Lock Powerbolt 1000 Lock
May 22, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Jun 25, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Nov 02, 2008 | Kwikset Powerbolt/Electronic Deadbolt-...
Aug 19, 2008 | Hitachi 51F500 51" Rear Projection...
Mar 29, 2008 | Sentry Fireproof Safe
202 people viewed this question
