Question about Casio Office Equipment & Supplies
Http://support.casio.com/pdf/004/fx115MS_991MS_E.pdf copy and paste this address into your browser's address window and download the owner's manual
Posted on Jan 15, 2018
SOURCE: how can i use casio 991ms to solve all statistics
first off you want you calculator in SD (standard deviation) mode to do this hit mode twice and then 1.
next it is good practice to start off by clearing the memory to do this hit shift, CLR,1 and then = this will clear statistical memory
to enter values into your data set , you enter the value, then press the DT (M+) button. (note: pressing DT repeatedly will impute the same value multiple times)
once you have finished pluging in your numbers your calculator can give you statistical information about the data set.
hitting shift then 1(S-SUM) gives you three options:
1 the sum of the squares of each value
2 the sum of each value
3 the number of terms in the data set
hitting shift then 2 (S-VAR) gives you three more options
1 x bar (the mean)
2 x sigma n (the population standard deviation)
3 x sigma n-1 (the sample standard deviation)
you can use these tools to solve alot of statistical problems
i hope this helped
Source: http://support.casio.com/pdf/004/fx115MS_991MS_E.pdf
page 28 of he pdf
Posted on Mar 30, 2011
SOURCE: m mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Posted on Jun 29, 2009
SOURCE: casio fx-83ES
there is a button SD close to AC button, standard - decimal try it .......or
shift+mode format math IO, change it to the other option
Posted on Dec 03, 2008
SOURCE: how to calculate log value in calculator with different base value
In any scientific calculator log2(n) can be calculated with either ln or log function as
follows
Log2(n)= ln(n) / ln(2)
Or
Log2(n)=log(n) / log(2)
both will give nearly the same answers
Posted on Apr 24, 2009
SOURCE: how to calculate inverse of a 3x3 matrix in casio
Here is the solution for th FX-991ES.
The error may be due to the key you used to signifie
inverse. It says in the manual that you should use the key x^-1 not the
one used to input general powers.
Here is screen capture from the
Appendix to the manual. The picture shows the sequence of keys to press
to obtain the inverse of a 2x2 matrix. It is taken from page 41 of
Appendix
The matrix used in the exemple is
a_11=2 a_12=1 a_21=1 a_22=2
Here is the link to download the manual and the appendix
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
The link is for FX991ES. Look there foe you manual.
Hope it helps
Posted on Sep 07, 2009
Jul 25, 2013 | Cameras
Oct 22, 2011 | Casio FX-300MS Calculator
Aug 31, 2011 | Casio fx-300ES Calculator
Mar 14, 2011 | Casio fx-300ES Calculator
Nov 28, 2010 | Casio FX-115ES Scientific Calculator
Jul 15, 2010 | Casio FX-115ES Scientific Calculator
Mar 10, 2010 | Texas Instruments TI-84 Plus Calculator
Oct 19, 2009 | Casio FX-300MS Calculator
Sep 27, 2009 | Casio fx-300ES Calculator
Jun 29, 2009 | Casio FX-115MS Plus Calculator
696 people viewed this question
