Firstly, I'm not going to ask how you know what a moose in heat groans like!
secondly, more on topic ( ?? ) those sort of noises are normally either the drum bearing or belt drive. Remove the back panel and rotate drum by hand, you should be able to listen to where the fault is.
good luck with the mooses!
Testimonial: "It is the rear fan motor making the noise. The bearing is shot. I've already ordered the new fan but Im having trouble removing the fan. I removed the four fanblade screws but the motor is not coming out"
