Question about Wharfedale Audio Players & Recorders
One of our Wharfedale Titan 12 speakers has stopped working - no Power On LED, Limit LED flashes about one per sec. Is there a fuse I can check or anything else before sending to the repair shop?
Posted by David Scott-Morgan on
5 Related Answers
Anonymous
  • 105 Answers
SOURCE: Stopped working suddenly after 18 months daily use
It appears either the inverter supply board or the main video board have failed. First replace the inverter board, if not fixed, replace the video board. Mike
Posted on Aug 09, 2006
siggy7488
SOURCE: Service Call 17H
had this message 17H after unpacking the Magicolor 2300 W.
Here's the step by step way to fix it, done with the help of an online technician on the phone.
Cause : one of the toner cartridges was unproperly installed in factory, or went loose during transport, so the whole toner rack is out of synch.
Solution : manually take out and reinstall ALL cartridges and reboot.
Time : 10 mins
IMPORTANT 1 : turn off the printer and UNPLUG it as you need to "erase" the error from its memory.
IMPORTANT 2 : this is a manual intervention, byp*ssing the electronic-*ssisted way to replace cartridges. As such, there's a risk to damage the unit.
IT'S YOUR CALL :D
How (you need to use the printer parts'names in the small manual):
1. Take out the waste toner bottle.
2. Release the transfer unit release blue lever clockwise to upper position (11:00)
3. Pull out the OPC drum cartridge and hide it in a box away from ambiant light
4. Now the fun part....
5. The toner cartridges are to be pulled out through the oval hole in the upper left corner. PLACEMENT IS CRITICAL.
Chances are there's not a cartridge ready to be pulled out as the rack is out-synch, u probably see 2 cartridges through the hole.
You need to manually rotate the rack for each cartridge BUT YOU MUST ACTIVATE ITS FREE-WHEELING FOR THAT.
DON'T FORCE THE ROTATION, YOU CAN DAMAGE THE UNIT.
6. About 1 inch to the left of the hole, there is a tiny rectangular hole with a circle button inside.
Use a flat screwdriver to push this button about 1 inch inside and hold it there.
(You know you're doing well if you can rotate the rack with one finger, almost like a bike's wheel...)
Then you can manually rotate the rack and take out each cartridge. AGAIN PLACEMENT IS CRITICAL, DON'T TRY AND FORCE OUT THE CARTRIDGE.
7. Take out all 4 cartridges.
8. Put them all back again, make sure you respect the color code (ie. C cartdrige is C slot, etc.)
9. Put back OPC Drum, etc.
10. Plug the printer and restart it.
That worked for me, the blue cartridge was indeed loose, no more 17H.
Best regards,
Taipan
This message was edited by taipan on 6-3-05 @ 2:52 AM
Also read that you could try turning the machine on and hit the change toner button. If it lets you change toner, then remove all the toner cartridges and install them again and see if that clears it up.
Posted on Jan 20, 2008
Anonymous
  • 85 Answers
SOURCE: It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Posted on Apr 22, 2008
Anonymous
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
Anonymous
SOURCE: Flashing OPC/DL light
Here's what I did to fix issues with my 37D5U - do at your own risk:
***Follow the instructions below to fix the same issue in your LC-37D5U tv***
Do this test first to confirm the failure:
(1) Connect the cable line to the tv.
(2) With the tv unplugged, hold down the Input and Volume-Down buttons simultaneously, then plug in the tv.
Expected result:
(a) You should hear the tv come on in the service mode; the OPC/DL and power lights on the front of the tv should turn green and blue, respectively.
(b) The broadcast sound should come through the speakers, but you will probably still have no picture or back light.
If your test yields the expected results, proceed to the fix.
Fix
Parts Needed
(1) Part type: Fuse
Location on circuit board: F705
Official Part No: QFS-A1154SNEZ
Replacement Part No: BK/PCB-1-R (Mfg: Cooper Bussmann - about $2) or the original QFS-A1154SNEZ (Distributor: Sears Parts Direct - about $14)
(2) Part type: Mosfet (4 of them)
Location on circuit board: Q723, Q721, Q719, Q717
Official Part No: k3469
Replacement Part No: FQPF13N50C or FQPF13N50CF (Mfg: Fairchild Semiconductor - about $2 each)
Fuse F705 is part of the circuit on the power supply that powers the inverter circuit, and the inverter switches on the back light for the tv. The mosfet at location Q723 was suspect when I tested it, so I went ahead and replaced it and the other three mosfets "chained" to it as preventative maintenance. Parts can be bought from digikey.com - digikey is usually a same-day shipper with the best prices, so I use them. USPS Priority shipping is the best bang for your buck.
Tools Needed
Philips screwdriver
Soldering iron
Desoldering braid or some other solder remover
Light bulb socket that has two wires running from it and a clear 100-watt light bulb - Home Depot sells the sockets. Alternatively, you can use a 2K ohm/10W resistor
Multimeter - not necessary, but helpful
Procedure
(1) **Important: Make sure the tv is unplugged**
(2) Remove the back cover and stand - there are a bunch of screws holding the back cover on. You can either mark the screw locations and bag the screws or do what I did: Unscrew the screws, leaving them in their holes, then slowly lift the back cover off and carefully set it down with the screws intact.
(3) Set the tv on a flat surface with LCD panel facedown and remove the AC power cable.
(4) The board you want to work on is the power supply board (see pic below), which is the board where the AC power cable connects. Carefully detach the connectors that connect to the other boards in the tv from the power supply, then remove the screws that hold the power supply to the back of the tv and lift it off the tv by holding it by its edges.
(5) Locate the four large 450V capacitors at locations C734, C709, C710, and C852 without touching them (they look like soda cans). Flip over the power supply board. Touch each wire of the socketed light bulb or resistor for about 3 seconds to the negative and positive leads of each large capacitor, respectively; polarity is irrelevant. This discharges the high voltage from the capacitors so you don't get shocked while working on the power supply. The voltage usually slowly dissipates on its own, but it's better to be safe than sorry when you're talking about a potentially lethal 450V. Check the voltage with your multimeter in the appropriate DC mode to verify that the capacitor voltage has been drained; if you don't have a multimeter, just continue on.
(6) At this point, you can verify that the fuse at location F705 (looks like a small black box) has indeed failed by holding the multimeter's red and black probes on the fuse's leads with the multimeter in continuity mode. If you have no continuity, the fuse has internally failed; proceed to the next step.
(7) Desolder the fuse from location F705 and desolder the mosfets from locations Q723, Q721, Q719, and Q717 then replace with new components.
(8) Put the power supply board back in the tv, using just a couple screws to hold it in for now. Reattach the connectors to the power supply.
(9) Attach the broadcast cable line.
(10) Reconnect the AC power cable to the power supply (don't plug it into the wall socket). Hold down "Input" and "Volume-Down" simultaneously, then plug in the tv. The tv picture and sound should come on.
(11) With a small screwdriver or other probing device, depress the Reset button, not the System Reset button; it's the last recessed button below the cable jack on the back of the tv. The tv will reset, then you should get sound and a picture from channel 2.
(12) Reinstall the remaining power supply screws, back cover, and stand.
Posted on Dec 30, 2010
Compatibilty
If what you say is true, you should be fine.
Where you get into trouble is having an amp of higher power than your speakers. That means you will likely blow your speakers.
Nov 12, 2014 | Audio Players & Recorders
Why does my acer aspire e1 571- 6482 not start or charge anymore? only the on led and batt led flash.
pressing power on button should be for 30 to 40 sec but the flashing lights means there is a hardware problem can find flashing light codes on the net you could try removing ram 1 by 1 c if that works hope this helps if not will keep an eye on this
Jul 29, 2014 | Acer Aspire E1-571-6650 Laptop
Wharfedale problems
Take it to a repair shop. You have a short circuit or too small a fuse. Have an expert check it before you try to use it again.
Apr 05, 2014 | Wharfedale Titan 12 ACTIVE 12" 2-Way...
I have just bought a Wharfedale ICS182 in-car radio but it doesn't seem to work. The red light that indicates power works but nothing is happening. Please help.
Take the control panel off.
Turn ignition off.
The alarm led should flash slowly.
Turn ignition on
The alam led should flash quickly.
If it stops flashing, take the radio out and get it repaired/replaced under warranty.
Dec 28, 2010 | Car Audio & Video
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Wharfedale Powercube uncontrollable loud noise
Change the 2 elco's in the supply
6800µF 63Volt
Aug 01, 2009 | Wharfedale PowerCube PC-12 Subwoofer
Cant set the clock on my Wharfedale ip76 stereo.
Hold down iPod/MEM/C-ADJ till it flash's 24 Hours, choose between 24 & 12 hour clock, press MEM again to move onto hours, MEM again for minutes, MEM again to save the time
Nov 15, 2008 | Wharfedale Open Box WH-LOUDM-LIM LOUDMAN...
Loud steady sound when turned on
If it's a humming noise you are describing, then it may be that one of the power supply filter capacitors has failed. Of course it could be some other sort of power supply problem as well.
Dec 14, 2007 | Wharfedale PowerCube PC-12 Subwoofer
93 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
