My splendid wash dryer door will not lock lights come on but will not work.
2100
Posted by Utah Bentley on
Kevin.
    Sergeant:
  • 256 Answers
Needs a new door mechanism on the locking side.
Posted on Jan 14, 2018
5 Related Answers
prem mathew
  • 1294 Answers
SOURCE: Splendide 2000S
Go to: repairclinic.com
Posted on Mar 13, 2008
Anonymous
SOURCE: Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Posted on Nov 01, 2008
Anonymous
  • 3 Answers
SOURCE: Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Posted on Jan 28, 2009
Anonymous
  • 4 Answers
SOURCE: splendide 2100 vented washes clothes just fine but
This means that the washer has found something wrong and it is going to a diagnostic mode. When the knob starts going around, immediately begin counting how many times the red light blinks. Call Splendide and they can diagnose the error from the number of blinks you counted. I would recreate the problem more than once so you know that you counted right.
Posted on Aug 28, 2009
Anonymous
SOURCE: splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
Posted on Dec 21, 2009
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
Splendid 2000s washer dryer door won't lock
Possible that the door lock is jammed and needs to be replaced.
please check this link;
Replacing door lock
Jun 06, 2012 | Splendide Washing Machines
Where can I find parts for the Splendite Washer/Dryer unit model WD2100
westland sales splendide parts ordering and tech support 800 356-0766
Mar 13, 2010 | Splendide 2100 Vented Washer-Dryer
Door locked
THE CAPACITOR IS FAULTY that discharges so door can be opened safely it should be at the rear of mc inside attached to the side of mc make sure u get correct microfarfad replacement
Jan 13, 2010 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 washer/dryer now fails to dry -
Sep 19, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 vented washes clothes just fine but now when it goes into the dryer mode just roates the knob around without doing anything. This only happens in the dry mode.
Jul 07, 2009 | Splendide 2100 Vented Washer-Dryer
Jan 27, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2000 Vented won't work
If you are talking about you have power to the washer/dryer but the machine won't even turn on, won't spin, won't add water, won't turn on dryer, then your situation is like mine right now. Last week with the same situation, we remounted the security switch in the door lock where the little hooks goes into the washer and the machine worked for about a week. Now the same thing is happening and I am looking for a replacement switch.
I definitely need help in getting the washer out of its cabinet and get the cover off in order get to the switch from above.
Jeff
Aug 31, 2008 | Splendide 2100 Vented Washer-Dryer
Broken Handle
Contact this person and his company. They have the handle kit for the WD-2100
Darrell Klein National Service Director
Westland Sales /
Splendide Combination Washer Dryers
15650 SE 102nd Ave.
Clackamas, OR 97015
503-210-3914
[email protected]
Jun 30, 2008 | Splendide 2100 Vented Washer-Dryer
Marvin
Marvin
