Question about Maytag Refrigerators
SOURCE: MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Posted on Sep 15, 2008
SOURCE: Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Posted on May 04, 2009
SOURCE: Fan running but neither refrig or freezer is getting cold.
Your refrigerator may be stuck in defrost cycle. I know it has a defrost timer part number 215846602 Most times they are located inside the fresh food compartment behind the control panel. Sometimes below fridge and behind kick plate. The thermostat could be defective also. You can check that by unplugging the refrigerator remove cover and checking continuity between the two male connections located on the rear side of thermostat control turned as cold as you can turn it. Or you can join the two wires together and plug refrigerator back in to see if compressor comes on. When you find the defrost time turn clockwise slowly until the refrigerator starts. If these don't work let me know and we will do some more test. Sea Breeze
Posted on Jun 20, 2009
SOURCE: GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Posted on Jun 30, 2009
SOURCE: Our side by side is leaking water in a puddle on
I'm going to give you a lot of information on one page please choose thye part that most defines your situation and I will be here to assist you, Please rate me, Thanks, Sea Breeze
Click Link Below
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Posted on Aug 12, 2009
Mar 04, 2014 | Refrigerators
Jun 25, 2012 | Maytag MZD2766GES Side by Side...
May 21, 2011 | Maytag EPIC MFW9700S Front Load Washer
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Apr 18, 2010 | Maytag Refrigerators
Aug 12, 2009 | Frigidaire 18 Cu. Ft. Bisque Top Freezer...
Aug 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Aug 18, 2008 | Maytag MZD2766GES Side by Side...
May 15, 2008 | Maytag Refrigerators
