My phone won't turn on at all and I'm scared that it won't turn on ever again!
I purchased a Cubot HAFURY UMAX Phablet a few weeks ago and have had no problem with it...until recently. Not too long ago, I fell asleep and forgot to put my phablet phone/tablet on its charger, so it died before the night was over. I quickly learned that while my phablet's battery life lasts longer than any other phone I've owned before, it also takes just as long to charge. Let's just say that it's been a bit since my phablet has been completely 100% charged. So, I decided to put it on its charger a little earlier than usual last night in hopes of my battery having a little more life for when I would need it. It was doing fine before I went to sleep. But, when I woke up, I noticed that the screen wasn't lit up with new notifications like it would usually be. I didn't pay much mind to it until I reached for it to check the time like I do every morning and received absolutely no response. All I got was a little flicker of my LED. Thinking it might have been frozen, I quickly took it off the charger and removed the battery. I put the battery back in and attempted to turn the phablet on again and still received no response. The only time I receive a response is if I put it back on the charger, and the response is from only the LED. I've held down the power button and taken my battery from my phablet several times, but it still won't turn on. I'm hesitant to try anything else/more for fear of messing the phablet up even more. Could it be that I've simply overcharged my battery? Or is there a possibility that it's much worse?? Please help!
If your Cubot King Kong 5 is asking for a "privacy protection password" when you turn it on, and you did not set one up, it is likely that the device has been locked by someone else who has set a password. In this case, you will not be able to access the device without the password.
There are a few possible solutions to this problem, depending on the specific circumstances:
If you are the owner of the device and you did not set a password, you may be able to reset the device to its factory settings. This will erase any personal data and settings on the device, including the password. To reset the device, you will need to follow the specific instructions for your model of Cubot King Kong 5. You can find these instructions in the user manual or by searching online.
If you are not the owner of the device and you do not know the password, you may be able to contact the manufacturer or a qualified repair technician for assistance. They may be able to help you unlock the device or reset the password.
If the device is locked and you are unable to reset it or unlock it, you may need to purchase a new device. It is not possible to bypass the privacy protection password on a device without the correct password.
In conclusion, if your Cubot King Kong 5 is asking for a privacy protection password and you did not set one up, you may be able to reset the device or contact the manufacturer for assistance. However, if you are unable to reset the device or unlock it, you may need to purchase a new device.
Try phone reset Power off the phone, hold the volume down key and press down the power button simultaneously for about 15 seconds. The phone will power up and shows an exclamatory mark. Then release the button. Press the volume down key, it will display the menu. Choose the menu by press the volume down key. Choose "wipe data/factory reset", press power key to enter in, then choose "delete all user data", press power key to confirm. Wait until it indicates "data wipe complete". Then choose "wipe cache partition", confirm with power key. Wait for a few seconds, the screen will shows "cache wipe complete". And at the last, choose "reboot system now", confirm with power key, then the phone will reboot.
You should be able to use your SIM card in any phone as long as the phone is not locked to a network. Whether your calling plan allows data is another issue.
Most of the time Windows drivers are backwards compatible. (one exception, is the 64 bit OS) Try this site for fresh drivers, come back if this does not lead to a fix.
make sure the driver in properly installed, to make sure try to uninstall the driver then restart your system then install again the driver. moreover double check if your webcam was detected by your computer and check its connection.
