Question about Internet Computers & Internet
Want back to internet explorer - Internet Computers & Internet
Posted by Betty Crowe on
nejones57
    New Friend:
  • 3 Answers
Assuming you're using Windows 10, type Internet Explorer into the search box at the bottom of the screen. Find Internet Explorer in the list of results, right-click it to either Pin to taskbar or Pin to Start. To make IE the default browser: Start button> Settings> System> left side menu, select Default Apps then select Set Defaults by App
Posted on Jan 13, 2018
When I unistalled internet explorer 8 by accident but how do i reinstall internet explorer ?
Oops! Well, it may not be such a bad problem. This is what Microsoft has to say about it:
Reinstall Internet Explorer in Windows 8.1 and Windows 8 Because Internet Explorer is now a Windows feature in Windows 8.1 and Windows 8, you can't uninstall it. However, you can turn it off. To do this, follow the steps in the "Turn off Internet Explorer" section in Install or uninstall Internet Explorer (http://windows.microsoft.com/en-in/internet-explorer/install-ie) .
After you turn off Internet Explorer and then restart your computer, Internet Explorer will be removed from your computer.
You can also turn the Internet Explorer Windows feature back on to reinstall it on your computer.
Feb 04, 2015 | Dell OptiPlex Computers & Internet
Tip
For All XP user Don't Use IE 7.0 & higher version
Applicable for all window XP (all edition, all PCs and Laptops)
If you are getting trouble after the updates of internet explorer..
Then I would suggest you to Roll Back it to the original Internet Explorer (i.e Internet Explorer version 6.0)
Which come up with Installation of Win Xp with Service Pack 2.
Bad Effect due to IE 7.0 or higher version:
Screen hang up, internet freezes abruptly, prominent windows crashes anytime.
So to stop these problems, better to run with lower and safe version of IE:
To remove Internet Explorer 7 from your PC use the following methods
Method 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
Step 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
a. Click Start, and then click Run.
b In the Open box, type appwiz.cpl, and then click OK.
c. In the list of programs, click Windows Internet Explorer 7, and then click Remove.
d. Follow the wizard instructions to uninstall Internet Explorer 7. Also remove if any updates under this entry found.
If you cannot uninstall Internet Explorer 7 by using this method, try Method 2.
Method 2: Use Spuninst.exe to uninstall Internet Explorer 7
Run Spuninst.exe to uninstall Internet Explorer 7
b. In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
c. Follow the wizard instructions to uninstall Internet Explorer 7.
After you uninstall Internet Explorer 7, double-click the Internet Explorer icon to verify that Internet Explorer 6 is restored.
This will bring up you to run Internet explorer as it come up with the installation kit, which is safe and reliable.
Have Nice Surfing!!
Ellin
on Oct 14, 2008 | Microsoft Windows XP Home Edition
I made a mistake and took off my old internet explorer and i am trying to get it back can you help me to get my old internet explorer back on
You can download internet explorer for free from this web page:
http://windows.microsoft.com/en-US/internet-explorer/products/ie/home
Please rate my Advise if it was helpful.
Aug 07, 2011 | Yahoo Mail
I don''t like internet explorer 9 and how you get
1. Uninstall Internet Explorer 9 through by going to control panel, programs, and click uninstall next to IE9 2. Download Internet Explorer 8 here: http://www.ie8optimized.com/ 3. Install the .exe
Jun 01, 2011 | Audio Players & Recorders
Internet Explorer is not working. What I can do to get it back. I try different thing to get it back, but it was imposible. My son was plaing and delate internet explorer.
To reset Internet Explorer settings
  1. Close any Internet Explorer or Windows Explorer windows that are currently open.
  2. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Internet Explorer.
  3. Click the Tools button, and then click Internet Options.
  4. Click the Advanced tab, and then click Reset.
  5. Select the Delete personal settings check box if you would like to remove browsing history, search providers, Accelerators, home pages, and InPrivate Filtering data.
  6. In the Reset Internet Explorer Settings dialog box, click Reset.
  7. When Internet Explorer finishes restoring the settings, click Close, and then click OK.
  8. Close Internet Explorer.
    Your changes will take effect the next time you open Internet Explorer.
Notes
  • If you close all visible windows, but still get an error message when trying to reset, you might have programs running that are not visible. Restart Windows, open Internet Explorer, and try resetting again.
  • To back up your home page or home page set before resetting Internet Explorer defaults, see Back up your home page or home page tabs.
  • If any of the categories fail to reset, it is because Internet Explorer could not access a file or registry setting. This can be caused by insufficient security privileges, files or settings being used by another program, or low memory or high CPU usage. You can either continue to use Internet Explorer without restoring these settings, or restart your computer and try to reset again.
  • If you are using Internet Explorer on a server and have turned off Enhanced Security Configuration or hardening (stronger security settings for use on servers), reset will go to client-level security. You must reinstall hardening if you want the increased security level. For more information on Enhanced Security Configuration, see Enhanced Security Configuration for Internet Explorer online.
  • To re-enable add-ons, see Internet Explorer add-ons: frequently asked questions.
Dec 28, 2010 | ZT Group CISNET A7050 PC Desktop
I m enable to download internet explorer
just go to the control panel ...click on add remove software ..and from the list remove the Internet explorer ...This will roll back to the last internet explorer you had..If in the list there is not an Internet explorer program ..it means that indeed there was no installation and you are at the IE 6 now....In this case just download and try to install it again ..this time do not make anything else during ..and follow the instructions ..
this is where you can download it ..http://www.microsoft.com/windows/internet-explorer/default.aspx
Jul 14, 2010 | Microsoft Internet Explorer 8
It just went of yestrday and cannot get it back on to facebook
due to some updates, this could be possible follow this steps:- first do system restore and take the system to back date configuration when it was working fine.
if you have xp or vista then uninstall internet explorer 8 either from add and remove prog from control pannel in xp or prog and feature in vista comp and then click view installed updated, find windows internet explorer 8 right click and then uninstall.
note:- before uninsatlling make sure . open internet explorer click on help/about internet explorer and check the version.
afrter uninstallation restart the computer and internet explorer 7 will get reinstall automatically.
reset the internet explorer. how?
start/run/type inetcpl.cpl/advanced/reset and then check the facebook. everything should work fine.
May 09, 2010 | Computers & Internet
AppHangXProcB1
Step 1: Open a blank page in Internet Explorer loadTOCNode(2, 'resolution'); Test Internet Explorer by opening a blank page. To do this, follow these steps:
  1. Click Start, click Run, type iexplore about:blank in the Open box, and then click OK.
  2. If Internet Explorer does not start, go to "Step 3: Start Internet Explorer in 'No Add-ons' mode." If Internet Explorer starts correctly, follow these steps to use a blank page as your home page:
    1. On the toolbar, click Tools, and then click Internet Options.
    2. On the General tab, note the address that is listed in the Home page area. This address may cause the problem.
    3. Click Use Blank, and then click OK.
    4. Close Internet Explorer. Then, start Internet Explorer again.
uparrow.gifBack to the top Step 2: Remove temporary Internet files, browsing history data, and Web form data loadTOCNode(2, 'resolution'); To remove temporary Internet files, browsing history data, and Web form data, follow these steps:
Windows Internet Explorer 8
  1. Start Internet Explorer.
  2. On the toolbar, click Tools, and then click Internet Options.
  3. On the General tab, click Delete in the Browsing history area.
  4. In the Delete Browsing History dialog box, click to clear all of the check boxes except for the following check boxes:
    • Cookies
    • History
    • Form Data
  5. Click Delete.
  6. Click OK to close the Internet Options dialog box.
  4. In the Delete Browsing History dialog box, click Delete files, and then click Yes in the Delete Files dialog box.
  5. Click Delete cookies, and then click Yes in the Delete Cookies dialog box.
  6. Click Delete history, and then click Yes in the Delete History dialog box.
  7. Click Delete forms and then click Yes in the Delete Form Data dialog box.
  8. Click Close, and then click OK.
Test Internet Explorer to verify that it works correctly. If problems still occur, go to the next step. uparrow.gifBack to the top Step 3: Start Internet Explorer in "No Add-ons" mode loadTOCNode(2, 'resolution'); To start Internet Explorer in "No Add-ons" mode, click Start, point to All Programs, point to Accessories, point to System Tools, and then click Internet Explorer (No Add-ons). To continue to your home page, click the Home button.
If the problem does not occur after you use this method, use Manage Add-ons to determine which add-ons are causing the problem. To do this, follow these steps:
  1. Click Tools on the Internet Explorer toolbar, and then click Manage Add-ons.
  2. Click the name of the add-on at the top of the Toolbars and Extensions list, and then click Disable.
  3. Click Close, and then test Internet Explorer.
  4. If the problem still occurs, open Manage Add-ons, enable the add-on that you disabled in step 2, and then repeat steps 1 through 3 for the next add-on in the Toolbars and Extensions list.
  5. Repeat steps 1 through 3 until the problem is resolved or until all the add-ons have been tested.
  1. Click Tools on the Internet Explorer toolbar, point to Manage Add-ons, and then click Enable or Disable Add-ons.
  2. Click the name of the add-on at the top of the Enabled list, and then click Disable in the Settings area.
  3. Click OK, and then test Internet Explorer.
  4. If the problem still occurs, open Manage Add-ons, enable the add-on that you disabled in step 2, and then repeat steps 1 to 3 for the next add-on in the Enabled list.
  5. Repeat steps 1 to 3 until the problem is resolved or until all the add-ons have been tested.
uparrow.gifBack to the top Step 4: Use another user name to log on to Windows loadTOCNode(2, 'resolution'); Using a different user name and password to log on to Windows can help determine whether this problem occurs only when you use a particular user account. After you log on, test Internet Explorer to see whether the problem still occurs. uparrow.gifBack to the top Step 5: Reset Internet Explorer settings loadTOCNode(2, 'resolution'); To reset Internet Explorer settings, follow these steps:
  2. Click Tools on the toolbar, and then click Internet Options.
  3. On the Advanced tab, follow one of these steps:
    • In Internet Explorer 8, click Reset, click Reset in the Reset Internet Explorer Settings dialog box, and then click Close.
    • In Internet Explorer 7, click Reset, and then click OK.
  4. Test Internet Explorer to determine whether the problem is resolved.
Nov 26, 2009 | Acer Aspire 5315 Notebook
Internet explorer 8
Just go to add or remove programs and then u can see internet explorer 8. Click on uninstall and revert back to ie 6 or ie 7. If it reverts to ie 6 then download n install ie 7 if you need.
Jun 20, 2009 | Microsoft Internet Explorer 8
How to fix That problem
Click On Start --> Control Panel --> Add Or Remove Programs --> Make Sure That The Show Updates Box On Top Of The Window Is Checked --> Find WINDOWS INTERNET EXPLORER 8 --> Click On Remove In Front Of It.
WINDOWS INTERNET EXPLORER 8 would be removed and will ask u to restart your system so kindly do that...
After The System Restarts, Follow These steps To Check Whether It Has Removed Windows Internet Explorer 7 as well and if it has you would not see WINDOWS INTERNET EXPLORER 7.
As Internet Explorer 6 Is Integral Part Of Windows XP You Won't See It In Control Panel.
If WINDOWS INTERNET EXPLORER 7 is removed then click the link below and download and install WINDOWS INTERNET EXPLORER 7..
Click Here To Download Internet Explorer 7
In Case You Wish To Download Any Other Version Of Internet Explorer Then See Right Hand Side In The Green Pane And Click any Version Which you Want And Download And Install It From The Same Link As Given Above...
May 31, 2009 | Microsoft Internet Explorer 8
Computers & Internet Logo
60 people viewed this question
 Grubhead
Grubhead
Geoff
Sharps s
