Question about Locks & Locksmithing
Is there a weather proof rubberized cover for KABA e1000 unican locks to keep buttons from freezing
Posted by Donald Edward Smith on
5 Related Answers
Thomas F. Schneider
  • 2715 Answers
SOURCE: want to reprogam keyless lock
Turn knob once. Put in present combination. Open screw on the top, Use a small rod or drillbit  that will fit into the hole. Press straight down on a lever that is inside of the hole,until it clicks. Turn knob completely(once) to clear old combination. Put new combination in, making sure that a click is heard upon pressing each button.  Try knob with both the old and the new combination. Each digit may be used only one time in the combination.
Posted on Mar 05, 2009
Anonymous
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
brector3
shaveroutlet.com
  • 1641 Answers
SOURCE: Hello, I have a Remington, Titanium, MS 280,
This 'cover' is not availble as a replacement part. In fact, NONE of the parts on the body of this shaver model are available as replacement parts. Only the foil, frame and cutters are available as replacement parts
Furthermore, this is a discontinued model. Replacing it with another MS-280 will be difficult. However, there is a similar model MS2-390 available from shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/remington-ms2390-microscreen-500-shaver-p-564.html
Posted on Oct 10, 2010
Coaltowner
  • 963 Answers
SOURCE: I have a Simplex Kaba
I believe you can find this to be relevant:
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
Posted on Mar 06, 2011
Coaltowner
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
How can i remove a unican lock
You will find installation manuals on this page:
http://www.kaba-ilco.com/kaba-access-control/Documentation-Support/292720/simplex-mechanical-pushbutton-locks.html
You may need to install Adobe reader if you cannot view the documents. There is a "Get Adobe Reader" link found just above the chart if you can't.
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Oct 04, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
How to make a house keeping authrization key
I don't know whether this can be done. I recommend that you contact Kaba Ilco directly for assistance:
Oct 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Ilco unican- USA We would like to receive the standard code, which it has when you purchase this safe
Jun 27, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How do make my simplex lock magnet proof
Call Kaba and ask them to send you a form, which they will - fill it in, send it back, and the kits to fix the alleged problem arrive a few days later. Note that it's likely they are already magnet proof unless you want to lug a 90lb magnet around with you, despite what the video alleges.
Mar 13, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Unican LL1011 lock - the code opens the lock correctly. If a wrong button(s) is pressed the lock does not open as I would expect but when the correct code is entered it then fails to open
I recommend that you contact Kaba Ilco with this problem--there may be nothing wrong with it at all, but you need an answer.
Jan 28, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Simplex unican L1000 lock, occasionally the top two buttons do not 'connect' when pressed. Can this be remedied easily?
Nov 11, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
We are trying to recode our simplex 7000 unican ilco lock (5 button). can you send instructions
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=14
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Sep 08, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
How to reset codes in Kaba ilco Unican 4000 access control
I have a Unican 4000 series door lock and need to find code for it
Dec 20, 2009 | Locks & Locksmithing
Lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
May 16, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
220 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Chris Walker
Chris Walker
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
