Tablets & eReaders Logo
M
Monique Scapino Posted on Jan 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stuck in fastboot mode and cannot shut off tablet
Dayton Computer
Level 3:
Master:
  • Master 669 Answers
  • Posted on Jan 12, 2018
Dayton Computer
Master
Level 3:
Master:
Answers
669
Questions
0
Helped
199976
Points
2079
Perhaps you may offer additional information regarding the device or product. Rephrase the question please
3 Related Answers
joelwilcox
Friendly PC Repair
  • 1274 Answers
  • Posted on Nov 03, 2009
SOURCE: On a seperate tablet PC I accidentally switched to
turn the pc off and turn it back on, when it boots back up hit the fn key for lcd/external monitor until it works by turning it off of course i mean hold the power button down for 8 seconds
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Anonymous
  • 689 Answers
  • Posted on Mar 01, 2011
SOURCE: I have a Coby Internet
these might be the initial stages of the re-flashing process ie:installing the OS or upgrading when you might connect a usb cable,im not familiar with your brand.
rmahershalal
Marshall Ross
  • 20 Answers
  • Posted on Nov 13, 2016
SOURCE: rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Rca tablet is stuck on fastboot mode
I DON'T KNOW. I HAVE HAD GOOD LUCK GETTING FREE ADVICE FROM RCA BY TELEPHONE.
My daughters babrie nabi tablet is stuck In fastboot mode and it wont do anything ?
H. Done a search on babrie tablet no resault ?? Do u mean Barbie ..cheers
Asus zenpad10 tablet stuck in fastboot mode
KEEP HOLDING THE POWER BUTTON UNTIL YOUR PHONES SWITCHES OFF OR PULL OUT THE BATTERY DIRECTLY(If Required) to exit the FAST BOOT MODE and then start your phone normally by pressing only the power button.
Also in case you were trying to enter the recovery mode to wipe cache or hard reset then keep holding the power button and volume DOWN button until you get vibration and release the power button and keep holding the volume DOWN button to enter RECOVERY.
Rca tablet how do i get out of fastboot mode
fastboot reboot
Source: Lenovo
Why is my tablet Stuck on entering DnX mode.Waiting for fast boot command...
my next book tablet is stuck in dnx fastboot mode, it will not unlocked, and it stuck on voice command
Tablet says, Entering DNX Mode: waiting for Fastboot command...
I would book mark these links. Below.
Copied from :
https://www.kingoapp.com/help/fastboot-mode.htm
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
https://www.kingoapp.com/help/fastboot-mode.htm http://forums.androidcentral.com/verizon-droid-dna/252896-how-do-i-turn-off-fast-boot-mode.html
WHAT DOES FASTBOOT MODE MEAN?
Fastboot is associated when you root Android. Here's a site that helps explain it better in detail: The Easiest Way to Install Android ADB and Fastboot Tools on Any OS
Hope this helps you get a better understanding of what it is.
Lenovo Tablet a8-50 is stuck in fastboot mode..can't turn on or off
if you able to take out the battery then remove the battery and reseat the battery, it will fix the issue (hope the battery has outside access). Hope it will help.
I'm stuck on the fastboot mode. how to turn this off?
Its under system / developer options settings just untick the fastboot option.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
