Question about The Watches
How do I change the battery on my stauer 19093 watch?
The backlight and digital features are still working, but the analog hands have stopped
Posted by R Gilsinger on
david donovan
  • 3 Answers
The manual is not helpful and neither are any of these other answers. There are TWO batteries in the 19093 Compendium Hybrid. There's a CR2025 on top that runs the digital side, and an SR626SW down below that runs the analog. You need to remove seven small screws holding the upper circuit board to access the tiny SR626SW battery. Be careful of the two brass springs and two contact plates for the pusher buttons, they can fall out. Take pictures at each step of the way, especially when you first remove the back cover.
Posted on Nov 22, 2018
ibewjm
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Here is a link to the manual.
https://www.stauer.com/pdfs/manuals/19093.pdf
Posted on Jan 28, 2018
5 Related Answers
gemineye61
Janelle Schoonover
  • 842 Answers
SOURCE: stauer watch will not work after battery change.
I have no ideal how old your watch is nor where you had the battery changed. Ideally I would take back to whom changed the battery to see if it was a good battery. If your watch is older it may be time for an adjustment.
Contace Stauer for further assistance at link following:
http://www.stauer.com/customer_service.asp
Good luck.
Posted on Aug 21, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Will the analog (hands) stop working on a Wave
Yes, definitely analogue part will stop, because it takes more power to move gears and hands. Replace battery and you'll be OK. Rate me, plz.
Posted on Mar 16, 2010
David Tolond
  • 2501 Answers
SOURCE: Watch hands not moving after battery change.
I suspect that there is a setting up procedure that needs to befollowed when the batteries have been replaced. (I had a similarproblem when I did this with my watch - although the hands were moving,they were incorrect!)
I was unable to find any instructions on their web site but if you go to their web site (/www.sekonda.co.uk/) or your own area web site for Seconda, at the top of the page you will see a store locator tab, click on this to find your local store and ask them for some instructions.
Posted on Jan 26, 2010
Anonymous
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
Posted on Apr 11, 2008
Anonymous
SOURCE: analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Posted on Sep 27, 2007
I am attempting to put new batteries (CR2025 and SR6265SW) in my Stauer Colossus Hybrid. I need a diagram to reassemble the watch. Is an internal assemble of the watch available?
I bet the batteries cost you more than 10 bucks. My advice is always have batteries replaced by a local jeweler. Cost $8 to $15 and is done whilst you wait.
Stauer 20410 Colossus Hybrid Analog Digital Stainless Steel Quartz Watch
How to change the batteries is not available online. Sometimes there are videos. You could ask the maker direct though.
Dec 05, 2017 | The Watches
Weide wh1103 watch hands stopped working.other functions still ok.
1. did you check the battery? some analog-digital watches have two batteries. one for analog and the other for digital.
if so, try to replace one of the battery.
2. maybe your watch need to clean the internal mechanism. bring it to service center.
Nov 01, 2017 | Watches
Hour, minute and second hands don't work, why?
Yes, there are two batteries in the 19093 (Compendium Hybrid). The first battery (CR2025) is visible as soon as you remove the back cover plate. The CR2025 controls the digital half of the watch and the back light. The second battery is underneath the circuit board that the CR2025 is connected to. There are 6 small screws that will need to be removed to lift the circuit board and gain access to the second battery. The second battery is an SR626SW.
Aug 22, 2014 | Watches
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 | Watches
I have a Timex Ironman T563719J. The digital clock is working, but the analog portion has stopped. Any ideas?
There are two batteries in the watch. One for the digital watch and the other for the analog watch. The battery for the analog side probably needs changing but when the back is opened, you might as well change both batteries.
Jan 18, 2011 | Timex Ironman T56371 Wrist Watch
Stauer watch will not work after battery change.
Good luck.
Aug 21, 2010 | Bulova Watch
Will the analog (hands) stop working on a Wave Ceptor when the battery is low/dead? Digital feature still works fine....watch about 4 years old
Mar 16, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
The hour/minute/second hands on my Timex Ironman not moving
It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
Jan 09, 2010 | Timex Ironman Triathlon 50 Lap Digital...
Watches Logo
1,594 people viewed this question
Top The Watches Experts
Paul Carew
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Watch Expert? Answer questions, earn points and help others
