Question about iLO Televison & Video
Where is the fuse located and what does it look like on an ILO television?
Posted by Sammye Campbell on
Where is the fuse located on my 42" ilo tv and what does it look like?
Follow the power cord or power jack, it will lead you straight to the fuse. While most fuses snap into fuse holders, some manufacturers solder their fuses in place.
Sep 09, 2012 | iLO Televison & Video
Power won't come on
No power signal lights appear?If no power lights try to check the fuse inside your TV.remove the back cover to see the fuse location.It is located besides the power supply.check it if busted,then replace the same value of fuse.Unplug first before removing the cover to avoid electric shock.thanks!!
Jul 07, 2011 | iLO LCT32HA36 Television
42 inch ilo tv black picture sound only
If the fuse burned out the the tv would not turn on at all. When the tv is on is the back light still on? If its not its probably the back light that needs changing. If its on then its one of the circuit boards.
Jun 02, 2009 | iLO LCT32HA36 Television
Cracked lcd trying to buy a ilo-32 hd lcd
You do know that the LCD display will be a few dollars short of a new set ? If your still interested in it then let me know.
May 20, 2009 | iLO 3200 32 in. LCD Television
Wont turn o
Hi
check the thermal fuse that is small white Ceramic Fuse maybe that is defective.
Thanks
Dec 05, 2008 | iLO 3200 32 in. LCD Television
Ilo 32 won't power up by remote or manual
i am sure that you have a power supply problem
check all the fuses
good luck
[email protected]
Oct 25, 2008 | iLO 3200 32 in. LCD Television
ILO IWT3206
the problem is one of the four diodes in the power supply.(i had the same problem) .the only other thing that would cause this is a shorted horizontal
output tranistor
Mar 15, 2008 | iLO 3200 32 in. LCD Television
Ilo LCT32HA36 LCD TV
HI, I AM JESSICA PORRAS. I PURCHASED AN ILO PLASMA 42" T.V. FROM WALMART IN 2006. THE T.V. LASTED 1 YEAR AND POPPED A FUSE. THE SCREEN WENT BLACK, BUT VOICE IS STILL COMING THROUGH. I DID HAVE WARRANTY AND MY MONEY WAS RETURNED. I HAVE A QUESTION AS FAR AS THE BRAND 'ILO' GOES. CAN THE PARTS BE CROSSED WITH ANOTHER BRAND? SINCE THE FUSE HAS POPPED, WE HAVE REPLACED THE FUSE 3 TIMES, AND IT KEEPS POPPING THE FUSE. THE LAST 2 FUSES HAS BEEN A CERAMIC FUSE AND IT WILL BURN THEM. THERE IS A SHORT AND WE ARE WANTING TO CHANGE OUT THE TRANSFORMERS. IF I CAN HAVE A TECHNICIAN CALL ME @ 432-553-6784cell OR 800-880-2817work M-F 8-5PM CST. YOU CAN ALSO RESPOND BY E-MAIL. THANK YOU, JESSICA PORRAS
Feb 04, 2008 | iLO 3200 32 in. LCD Television
Ilo 3200 32in. lcd
ILO use a lot of electricity up to 300 watts or more. Your outlet has to many devices on it.  Re route your other devices on another outlet.
Oct 12, 2007 | iLO 3200 32 in. LCD Television
Ilo tv
PUT IT ON THE TRUNK OF YOUR CAR AND DRIVE REALLY FAST. PERMANENT FIX!
Feb 08, 2007 | iLO 2600 Television
Televison & Video Logo
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
