I run water through the lid but over time I have coffee buildup. It is disgusting to drink coffee and have a lump of slime in it.
How to Clean Stainless Steel Coffee Mug Hunker
However from Stanley:
You'll need:
Instructions:
How to properly clean your Stanley products
SOURCE: Dishwasher leaves taste on glasses
hi there sounds like your rince aid level is set to high, the adjustment for this is located under the rince aid filler cap, try setting to position 2
SOURCE: amount of coffee produced
you clean the filter with what vinegar you need to use descaler descaler melt calcium vinegar vinegar remove calcium in pieces that might block the machine use descaler 1 part descaler 1 part water put solution in the water tank start the machine after a few second turn it of wait 10 to 15 minute after repeat untill empty rinse very good 2 or 3 full rinse that stuff is corosif thanks for using fixya pierre
SOURCE: Slime buildup in my washing machine
The slime is almost certainly the enzymes in the washing powder that are there to digest the dirt getting left behind.
3 things you can try:
A combination of 2 and 3 above should eventually get you where you need to be.
SOURCE: My Keurig just started only filling my mug 1/2
Have you tried following the descaling procedure given in your owner's manual? The mineral build-up from hard water can cause low flow, and since the machine pumps for a fixed time this means less water in the cup. Descaling usually brings back normal operation.
SOURCE: Coffee overflows onto the counter from time to
I believe
your problem is the filter basket holder is not seated correctly or the carafe
is not completely inserted in the unit to push the brew pause lever up. The
brew pause feature which stops the coffee from going into the carafe when you
want a cup of coffee before the brew cycle is done. When you remove the carafe
a spring lever stops the coffee from dripping into the carafe. When the carafe
is inserted it must push the spring lever up to allow the coffee to flow into
the carafe. If it is not the coffee will overflow and make a mess. The filter
basket holder should be firmly seated in the unit so it will not have any play
in it. Cuisinart recommends using a vinegar and water mixture but BrewRite
Cleaner (Sodium Carbonate) available in the coffee section at Wallmart, Kamart
and Target is fantastic. You can clean your carafe with BrewRite Cleaner and hot
water by letting it soak a few minutes and rinsing. I will also clean your
filter basket holder by soaking it as well and all your coffee residue will be
gone with no scrubbing.
