SOURCE: car cassette player
yes the rubber rollers inside your unit have become hard,,and they are slipping, and the unit detects this,, u can purchase a product called re-grip [ for rubber products and it treats the rubber in such a way to make it soft and pliable again ] the product is sold by mcm electronics and can be found online,,, treat the surfaces of the rubber rollers in your unit and it should preform to original specs....any further help please email me at [email protected] hope this helps you
SOURCE: Cassette player not working
Cassette players usually have a little rubber band that connects the motor to the spindles. If everything else is fine, I would suggest seeing if it slipped off somehow (or got cracked and snapped)
SOURCE: bad disc error on cd player
I'm sure these are good CD's that you are putting in (i.e. not scratched) but are they CD's that were burned from a computer? Some disk burned from computers cannot be read by older p[layers. If not than I would by a laser cleaning kit. This is a specials disk with small bristles attached to it. You add cleaning solution to some or one but not all. Then insert the disk in the player. This will clean the laser lens. The kits are cheap to buy but harder to find these days, check on-line but some department stores might have them. Check to see if the disk is spinning up by listening closely. Either way if cleaning the lens doesn't work you might have to replace the whole unit. Although, I suggest at that point to hard wire a aux input through the antenna wire. That way you can plug in a cheap MP3 player that can hold many of your CD's and play through your stereo.
SOURCE: Olds Cutlass factory radio/cassette, radio doesn't work.
When you say tried different radio and it didn't work, does this mean the tuner acts like it is functioning, but you hear nothing out of the speakers?
If so, this stinks of a bad ANTENNA...
SOURCE: need code to get radio/cassette player working. Thanks
have you tried 0000 its sometimes factory setting.
