Question about Smith Corona Office Equipment & Supplies
I have a Sears Smith Corona typewriter Metalist Power 12 871.36600 and the belt that operates the power ribbon advance has broken. its cut length is 8.5 inches and is approximately 1/8 inch dia.
Posted by Harley Porter on
5 Related Answers
JUSTOLDJIM
James Cagle
  • 482 Answers
SOURCE: fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
Posted on Oct 29, 2007
JUSTOLDJIM
James Cagle
  • 482 Answers
SOURCE: smith corona xd 6600
The ribbon is a one time use ribbon, Replace the ribbon cartridge with a new one.
Posted on Feb 02, 2008
male_28_cam
Aruna Singh
  • 1555 Answers
SOURCE: smith corona wordsmith typewriter model # ka13
The print head might have accummulated a lot of paper bits you need to clear them with a needle or just submerge the tip in petrol or ether. Caution do not submerge if its made of plastic.
Posted on Jun 21, 2009
Mike
  • 167 Answers
SOURCE: Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Posted on Oct 12, 2009
dkrippa
  • 327 Answers
SOURCE: Broken timing belt 1999 Toyota Rav 4. Can not
44a4ed6.jpgclick on view full page below 9afddd0.jpgor copy and paste it to save and enlarge it d2988d0.jpg7266c59.jpg3edfc84.jpga94c427.jpg2852d9a.jpg213369a.jpg
Posted on Aug 15, 2010
Testimonial: "This was exactly what I needed. Thank you"
Smith Corona-Model5 5P uses H ribbon. Spellright-correcting. Dictionary. Needa manual and ribbons.If you can help call 423-344-3516.
Smith Corona 5p Series Electronic Typewriter Parts ' Model ...
www.searspartsdirect.com/partsdirect/part.../Smith-corona.../0544000
Shop for Smith corona Smith Corona 5p Series Electronic Typewriter repair parts for model 335DLE(5ADF) at Sears PartsDirect. Find parts, manuals & diagrams ...
Mar 05, 2015 | Smith Office Equipment & Supplies
Manual for smith corona 250
Will Repair Service has all Smith Corona manuals ever published. Just log on to their Website and ask for the manual you need; www.willrepairservice.com.
Sep 17, 2014 | Smith Corona Office Equipment & Supplies
How do i reset the wheel on a smith corona sl460 electronic typewriter? the correction ribbon keeps coming out of place
The typewriter has a spring at one spool to keep the correction ribbon taut. If that spring is broken or out of place, the ribbon will always get in the way of the wheel.
If both ribbons are correctly set tight between the wheel and the paper, the typewriter will reset the wheel at power-on.
Some models reset the wheel every time you close the cover. You can see and hear it if it does.
Feb 16, 2010 | Smith Corona Office Equipment & Supplies
Corona 100 typing ribbon
Either a jammed ribbon or feed gears. Try another ribbon or get it serviced.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 14, 2008 | Smith Corona Wordsmith 100 Typewriter
21 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
