Question about Kenmore Vacuums
SOURCE: motor just stopped working
Kenmore Whispertone Model 26512690 PowerMate Brush motor does not run. The machine has no suction coming from the Power Mate Brush. However, I do have power in the main machine.
Posted on Aug 05, 2008
SOURCE: Belt broken a a Kenmore
Greetings from GoVacuum.com,
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled.
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
[email protected]
Posted on Oct 01, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
SOURCE: How to replace Kenmore canister vacuum filter.
I believe it faces toward the housing
Posted on Dec 19, 2009
SOURCE: I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Posted on Jan 04, 2010
