Hello -
I found some suggestions in an answer to a similar question for a different make of gas cook top. One of the suggestions here may be one you would wish to follow:
http://forums.whirlpool.net.au/archive/1772463
Best wishes.
SOURCE: I cannot REPLACEMENT KNOBS fOR model # 5D02
Hi, The part #74009592 for your knobs. This # is for a black knob. Let me know if I can assist you further.
Vic
SOURCE: replace dcs gas cooktop re-ignition module
donho1,
most likely the problem is the switch places onto the shaft of the valve. to replace the switch, you would need to remove the burner cap and port rings. you will see a large brass nut that needs to be removed on all 4 or 5 burners. next you would need to remove the nut in the center of the simmer port ring which is also the venturi for the main burner. you must be careful when removing this nut as they have a tendancy to lock onto the jet holder and could be hard to remove (don't strip or break the venturi or holder).....after you remove those nuts, the burners and top can be removed (watch the igniter wires). you can remove the switch by removing the retainer clip that holds the switch onto the valvestem.
SOURCE: KitchenAid Gas Cooktop KGCS105GSS08 grate rubber inserts
no parts available if the rubber u want, or get the tire rubber then cut it wat the size u want coz the tire is more hard compare to the other rubber.
SOURCE: I'm looking for replacement knobs for my Jenn Air
I agree...the knobs are a POS.......redesign needs to happen....
SOURCE: one gas cooktop does not light, no gas smell
Hello Liz. The most common reason for the problem you are experiencing is greasey dirt in the burner. Use a small brush, some fine wire and some degreaser to clean up the burner. Then let it dry overnight and try it again. If it still won't start, you will have to replace the ignitor.
