My tv will not connect to my wireless MiFi everytime I try it says and failed what to do
TRY the WPS button on the router, considering you have a wireless router. Write down the Key code listed on the WiFi Router as it may need to be used to connect your TV with the WiFi system. If your TV is NOT a Smart TV, you will need a USB WiFi receiver to attach to the TV. New Smart TVs have a built in receiver.
SOURCE: Acer Aspire 5100 won't connect to secure Verizon Mifi 2200
Delete the previous wireless connection than changed the key in router and than try to connect.
SOURCE: I have Samsung Star Wifi S5233W, everytime i go
Hi.. All you have to do is go to browser, then setting, then clear cache, empty cookies and delete history.. then restart your samsung star, then connect to desire wifi connection. then browse after setting up your browser profile. this work on me all the time.
SOURCE: my phone samsung gt-s5233w cannot
my phone samsung gt-s5233w cannot connect through wifi connection..everytime i try to connect the device, "dns failed" is always displayed
b4 connect to wifi restart yr cell and then connect yr wifi to cell it will work
SOURCE: I purchased a mifi 2372
Samething with me. I have a mifi and it can connect to the playstation but cant sign in. It says it a DNS error. Which means one of your DNS numbers have blacked out and it can be fixed by getting knew dns numbers.
You can try to reset the device. Here are the instructions for it. Also, you can get the instructions for it online. at http://www.novatelwireless.com/index.php?option=com_content&view=article&id=141&Itemid=50
This should help you. Here are the instructions. There is also an advisory on removing the battery out now. Please note this before you attempt to remove you battery. This step will not be necessary for the reset, but it is something you should know about your device. http://www.novatelwireless.com/index.php?option=com_content&view=article&id=247&Itemid=41
MASTER RESET INSTRUCTIONS:
The MiFi 2200 Device comes with a Master Reset button that allows you to return it to its factory default state.
The Master Reset button is recessed in a hold on the back of the device. You will need a paperclip or similar object to push the button.
? Make sure the MiFi Device is powered on.
? Locate the Master Reset button on the back of the device.
? Insert a paperclip into the hold and hold the button down for 5 seconds until the Power LED goes off.
Your list of wireless networks will now show the original default network when you first configured your device.
? Connect to MiFi Device again.
Hope this helps you. Please leave some feedback.
