U are exceding the load limit of the transmission for towing or u don't have enough trans fluid cooling capacity, if u have a cooler suggest installing a bigger one with its own electric fan
Either the motor winding shorted or; the connectors on the motor are loose/corroded causing arcing and overheating or; the linkage is binding putting too much load on the motor.
Sounds like the break rotors are warped. At this point its best to do a break job, chanses are the calipers are the problem not releasing and creating heat, or break lines are not returning fluid back to resavor witch in turn warp the rotors. Run the whole gamet on the breaks. New rotors, New calipers, New pads, and New rubber break lines to calipers. And you will solve your break problem.
