My lg inverter airconditioner won't turn on but flashes a green light 6 times would you have any idea what's wrong
Posted by Pammy on
vince
  • 1,234 Answers
Go to this site..
http://acerrorcode.com/lg-inverter-air-conditioner-fault-codes.html
there are a few things it means. you may need a tech.
Best to you.
Posted on Jan 10, 2018
5 Related Answers
Anonymous
  • 105 Answers
SOURCE: blinks 6 times
6 blinks mean low b error. you will ned to replace the g1 board
Posted on Oct 13, 2007
Anonymous
SOURCE: No power output from my vector 1000w inverter.
Buy a different brand of inverter. Yours has developed a short which the protection circuit is catching. It then tries a restart but fails all over again. Most likely o/p short which looks like an overload to the inverter.
Posted on Feb 01, 2009
Anonymous
  • 400 Answers
SOURCE: LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Posted on Mar 05, 2009
Anonymous
  • 81 Answers
SOURCE: Hello have a inverter LG Airconditioner and it
Error Code: C6 Problem: Inverter compressor run current high
SOLUTIONS:
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s)
Probably best to explain/print out and give to authorised serviceman
Mat
Posted on Jul 16, 2009
Anonymous
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Posted on Mar 06, 2010
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Error code for LG underceiling airconditioner
check error codes again LED 1 and LED 2. there is no 64 error code.
May 12, 2014 | LG Heating & Cooling
LG Lsk244v-3
you must reset the c.breaker from you panel house, and try again.
If the problem persist, replace the battery from r.control and try again. TURN ON manually, and see what happening. If turn on again, is o.k.
If the problem persist the control board inside is faulty .call some electrician or tech for help
God bless you
Jul 13, 2013 | LG Heating & Cooling
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
Jan 27, 2018 | LG Televison & Video
Hello have a inverter LG Airconditioner and it keeps turning itself off and showing the letters C6? Any ideas
SOLUTIONS:
- check run current
Mat
Jul 14, 2009 | LG Heating & Cooling
Jan 30, 2009 | Electronics - Others
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
