Vacuums Logo
Question about Kirby Vacuums
I cannot get the belt to engage on my Kirby Sentria.
Posted by Lorie Sarnes on
Pieter Vleeshouwers
  • Kirby Master
  • 2,029 Answers
Posted on Mar 21, 2018
4 Related Answers
Anonymous
  • 112 Answers
SOURCE: Engaging belt on Kirby G5
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. The hook stretches the belt so that it can fit over the fan drive.
Next, place the two "feet" of the powerhead onto the "perch" on the front of the kirby....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
then turn the belt lever from off to on.
the G5 should have a light on the powerhead that comes on (green) if the belt is spinning the brushes. That will let you know if you've got it on correctly.
Posted on Jan 04, 2008
Anonymous
SOURCE: kirby sentria
you have to make sure the green light is on.. in the corner .. and if it is that means its working properly. If you have no suction then it is usually the belt and or the bag. so make sure your bag is not full , make sure everything is attatched properly and the green light is on.... The Kirby is the best vac out there and little suction should never be a issue for us.. I am a proud owner of the sentria..Love it..
Posted on Jul 12, 2008
b0sslady2001
Marci Marple
  • 357 Answers
SOURCE: putting a new belt on
Please check out my step by step instructions.....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps...
Posted on Aug 28, 2008
Anonymous
SOURCE: Kirby Sentria
If the green light is off, then its time to replace the band. This video shows you how.
Posted on Dec 30, 2008
Sentria goes in reverse when pushed. Goes forward when pulled. What is the fix or adjustment?
Contact Kirby direct
Sentria - The Kirby Company - Kirby Vacuum
https://www.kirby.com > earlier-kirby-models > sentria
The Sentria Model includes softer lines and gentler curves on its design, giving it a sleek and soft look. The handle was redesigned on this model to provide ...
tip
How To Replace a Belt on a Kirby Generation G3-Sentria Vacuum Cleaner
Greetings,
Below we explain how you can replace a vacuum cleaner belt on the Kirby Generation upright vacuum cleaner. All you will need to perform this repair is a new Kirby Generation Upright Belt, and some time. No tools are needed to perform this repair. This repair is the same for all Kirby Generation models including: G3, G4, G5, G6, Ultimate G, Kirby Diamond Edition, and the Kirby Sentria. The repair procedures have to be followed exactly in order for the vacuum to work properly. This should be done at least once a year even if the belt doesn't break, because these belts will stretch out over that year time period and will not work as well as a new belt would.
I hope that you find this video helpful. If you do, please be sure to rate this Tip as helpful by clicking the Thumbs Up Icon in the top right hand corner of the Tip.
Feel free to send me an email anytime if you have any questions on the repair of the Kirby, or any vacuum cleaner.
Video Repair on how to Change a Belt on a Kirby Generation Vacuum Cleaner;
Thank you so much,
Chris Jones
GoVacuum
Kirby sentria 2
Make sure the belt is the right size.. It should be very very tight.
Apr 16, 2014 • Vacuums
Kirby Sentria 2 burning smell (not belt)
Actually it can. If the machine has a defect but the good news is that is has a 3 year warranty. Take it to a Kirby authorized repair shop not a vac and sew and they will fix it right up....I am a factory authorized service tech for the Kirby co.
2answers
Kirby sentria belt install
Make sure to follow this sequence (starting from the nozzle off and green arrows on the knob and label matching):
1. Turn the knob all the way to match the red arrows (make sure that as you are doing so the hook inside of the nozzle hoes through the belt and stretches it - you will feel that knob is prettu hard to turn)
2. Put the nozzle on the unit and fix it in the place with the latch.
3. Turn the knob back to match green arrows
There are some more detailed instructions and pictures on goodvac.com
YOU'RE DONE
1helpful
2answers
KIRBY ISSUES! :(
sounds about right you should change that type of belt every six months to a year regardless if its broken or not. one other thing you should do is make sure the brush roll itself isn't bound up it should spin freely if not you can pull the plastic ends off the roller to clean any hair or thread out .
3helpful
Kirby sentria
Top Kirby Vacuums Experts
David Shaub
Paul Bade
W.L.
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
