Question about JVC Car Audio & Video
How can I connect my phone in JVC KD-G635 ???
Posted by Ibraheem Mohammed... on
Austin
    New Friend:
  • 51 Answers
You need this add on Bluetooth adapter: https://www.ebay.com/i/253139680772?chn=ps
Posted on Jan 10, 2018
Testimonial: ","
  • Ibraheem Mohammed Saleh
    I had buy cable for aux in ( KS-U58). After plug to the port to the unit, can't found menu "Ext In". Pls help... Thank you
5 Related Answers
Anonymous
SOURCE: jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Posted on Mar 02, 2009
Anonymous
  • 655 Answers
SOURCE: How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
Posted on Jun 01, 2009
Anonymous
  • 84 Answers
SOURCE: My problem is when I connect my iPod to my head
That usb port is not meant for an ipod it was intended for a usb flash drive with mp3s on it. if you want to use your ipod you will need to get a interface mod, i believe the model number is jvc KS-PD100.. it should have it listed in your manual or you can call up jvc to confirm.
Posted on May 01, 2010
ozark333
Joe A
  • 396 Answers
SOURCE: How do I remove the JVC KD-G635 car stereo to gain
The bottom left button should release the faceplate. Most swing in on a pivot knob on the right side.
I could only find a manual for a KD-G637 . Hopefully it can work for you. See page 4
http://www.jvc.ru/files/instruction_manual/kd-g637_rus.pdf
Posted on Mar 19, 2011
Chris Ward
  • 158 Answers
SOURCE: I can't get my jvc kd shx700 to go into cd changer mode after i hooked up a cable from that input to rca connections to my phone
Try and go to standby mode if you have one and turn the aux on in the menu.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Posted on May 18, 2012
Can I hook up a mp3 or phone up to my jvc kd-s570
The KD-S570 does not support an Aux device (MP3 or phone) either with a Bluetooth or 3.5 mm connection directly. There are FM modulator or FM transmitter to Aux device retrofit kits that you can build/buy. (The FM transmitters require less work but can have lower sound quality.) The manual and specifications for the KD-S570 are available from the product support site: http://support.jvc.com/consumer/product.jsp?modelId=MODL026430 .
I wish that I had better news for you.
Apr 18, 2015 | JVC Car Audio & Video
Can I hook up my mp3 player to my jvc kd-s23 car stereo? If so, how?
I am thinking you can connect with a 3.5 m m. Jack, with left right input jacks connected to it. Going to give it a try. Also might try the phone the same way.
Aug 15, 2013 | JVC KD-S23 Car CD/ MP3 Player
Jvc kd-g635 set time
Follow the instructions in the "General settings--PSM" section beginning on page 12 of the manual.
Jul 07, 2012 | JVC Car Audio & Video
How do I remove the JVC KD-G635 car stereo to gain access to the rear of the unit.
u need special tools to remove the head unit if it was installed right. security purposes
Mar 19, 2011 | JVC AM FM CD DET FACE CAR STEREO
May 01, 2010 | Car Audio & Video
Bluetooth turn on
Hello imback2009,
The JVC KD-G140 does not have a Bluetooth option, either built-in or with an adapter. And as far as I can tell, it doesn't have a "mute" or "phone" wire which would allow installation of a generic bluetooth adapter, such as the Parrot. If you want to connect your cellphone, I'd recommend you look at an upgrade here.
Hope this helps.
Sep 11, 2009 | JVC KD-G140 Car CD Player
Where to get manual for JVC kd-lhx501
Hi - You can download the manual from the link underlined in blue below:
kd-lhx501
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 13, 2008 | JVC KD-LHX501 CD Player
Car Audio & Video Logo
207 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
