I have pensonic led-2416 diamond cut tv but the remote is lost what can ido,if i plug my tv its only a red color in power on.not working
MODEL:LED-2416 DIAMONG CUT PENSONIC...V-14069 1014-LED-2416-0187 SERIAL NUM
  • Stu Morris K Jan 19, 2018
    You can aslo use a mobile phone if its android based and use the app called Peel Remote this should give you basic functions like power on /off channel + - and volume +-
  • May Yap
    May Yap Aug 28, 2020
    what is code for pensonic for hiayu remote
Jack Frost
    Master:
  • 335 Answers
Google TV remotes and there are several choices there. You can order a universal one and then program it for your TV.
Posted on Jan 10, 2018
4 Related Answers
gopakumarg43
  • 76416 Answers
SOURCE: my 19"LED PENSONIC TELEVISION is DEADSET/NO POWER
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Posted on Jul 10, 2014
gopakumarg43
  • 76416 Answers
SOURCE: what is the code no.of remote pensonic model 1941.serial no.B09061863
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Apr 04, 2015
gopakumarg43
  • 76416 Answers
SOURCE: What is the code of Pensonic LED TV in Model 2424 in Keyin Universal remote control
0182,0188,0159,0153. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Posted on Oct 05, 2015
gopakumarg43
  • 76416 Answers
SOURCE: What code to open the service mode of pensonic model led-2424
If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Oct 07, 2016
Remote code for my Panasonic TV Viera TC-P50U50 to program my universal remote
Pensonic TV 3 Digit Remote Control Codes:
095
863
261
Pensonic TV 4 Digit Remote Control Codes:
3778
3779
2186
To program most universal remotes to work with your Pensonic TV:
1 - Hold the setup button until the light stays red or green.
2 - Be sure the light stays illuminated.
3 - Enter one of the remote codes provided above.
4 - Remote blinks and code is saved.
Nov 14, 2017 | Panasonic Televison & Video
Wheres the fuse of pensonic led tv
TV fuses are typically in the power section of the board.
Just look around the area where the power cord goes into the case and you should be able to find it.
May 06, 2016 | Televison & Video
CODEFOR PENSONIC TV
Hold down the TV power and power buttons together until the indicator blink twice. Key in 9-9-1. The indicator should blink twice again. Press the TV power BUTTON, Aim the remote at the decoder and press the CH+ channel up button and wait for three seconds again. Repeat the steps until the TV turns off. You`re basically iterating through the TV codes in the remote`s database. Press the OK button once you find the correct code.
Also try codes 0067, or 3778, or 863 for Pensonic. Some people have reported that these codes worked for them. Good luck!
Sep 28, 2014 | Televison & Video
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
Apr 01, 2014 | Proscan Televison & Video
Chunglap RM-133E codes
iam asking for the code of sharp t.v for chunglap remote controler thankyou./.
Apr 03, 2012 | Televison & Video
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
Aug 09, 2008 | Televison & Video
Televison & Video Logo
575 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
