Question about Canon Office Equipment & Supplies
Sir I hv canon mf3010 printer. It's always paper jam in fuser. Half paper out of fuser. Already change fuser, presiur roller, all of sensor but problem not fixing Plz help me
5 Related Answers
Anonymous
  • 87 Answers
SOURCE: paper jam
After the fuser, problably near the exit rollers, there is going to be a switch/sensor, that has a problem. It could be hung up, out of position, ect, but you have a typical exit sensor problem.
Posted on Feb 24, 2008
Anonymous
SOURCE: Canon Pixma iP1200 always reports "Paper is jammed"
not printer 5600 serveice ink who Repair it frome pleas helpe me thank you
Posted on Mar 04, 2008
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: Canon IR C3220 paper jam problem showing in the
Check to see if the EJECT SWITCH is hung up or out of it's holder.
Posted on Oct 30, 2009
Anonymous
  • 70 Answers
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Posted on Nov 03, 2009
Anonymous
SOURCE: Paper jammed at exit rollers of Canon D860. Paper
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
Posted on May 25, 2010
Out put jam in the printer 2600n hp
This could be a fuser issue or a paper exit sensor issue. Please take out the fuser and check the pressure roller. Be careful, the fuser is extremely hot.
May 11, 2015 | HP LaserJet Office Equipment & Supplies
Canon lbp 2900 paper jam
if paper jam at the half of of fuser unit then problem is with fuser or spong roller tell us location of jaming
Mar 31, 2014 | Office Equipment & Supplies
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
Sir ,ir 2020 paper jam at fusing unit.some times half of paper will come out,sometimes jams at the entrance of fusing unit.i changed every sensors,then changed new fusing unit,then feeding assembly...
Sometimes you can vlear a fuser jam with a manilla folder. Open the copier let it coll a bit and slide a manilla folder through the fusing unit. If it is just pieces of stuck paper the folder can sometimes push them out of yhe wsy ad you gorce it through and pull it out the other side. The fuser has two rolls one heat and one pressure both of these rolls have small fingers which are supposed to kerp paper from sticking to them. Sometimes these fingers get bent or damaged and this causes the actual jam. There is also an exit sensor that detects jams in this area it can have a damaged part as well
Jan 20, 2018 | Canon iR 2020i Laser Printer
Canon MF 6530 Paper Jams at fuser ,always the same about 2 inches through the fuser , Same issues from bypass tray is this mechanical problem or a electronic
it can be that sesor flaper in fixing unit has an slow response or the sensor is faulty. Also it can be that this is delay jam due to worn out paper feeding roller, or faulty pressure in fixing assy.
Recommendation is to call service!
Sep 16, 2011 | Canon MF6530 Black and White Copier
Sir my printer is canon mf 4320d sir it appears paper jam on display but i open rear and front cover but any paper is not found jam please help
I had the same issue, Turned out to be a tiny scrap of paper inside the fuser (the thing in the back behind the "caution hot" sticker. It was nearly impossible to see. I removed the screws on the fuser cover (to loosen, it wouldn't come off), then lowered the top lip enough to see the bright orange fuser roller. The paper scrap was stuck on the right side.
Sep 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Paper Jam
hi,
maybe your fuser assembly has a problem with fuser sleeves i think it's lack of silicon paste which is causing the jam on your fuser assembly. try to apply a silicon paste if have it but if not you need to drop it on a service center
rey
Nov 04, 2008 | HP LaserJet 1320 Printer
Paper jam
Are you sure you have the correct size paper?
Also check and make sure the exit rollers are turning, if not then there is a broken gear in hte fuser
Jul 23, 2008 | Office Equipment & Supplies
Paper Jams
How many copies has the copier done ?
When was the last fuser fitted ?(heated rollers)
the fuser rollers have a life of about 100,000 copies
and you change the whole unit at 200,000 copies
Feb 15, 2008 | Canon imageRUNNER C3200 Copier
Open Questions:
235 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
