Question about Ryobi Drills
Ryobi snowblower Ryobi 40volt lithium powered snowblower just click when trying to start. Battery indicates a full charge. Any ideas?
Posted by Jan Wolford on
Chris
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Bad connection in the switch possibly, if it can be opened it may be touched up with steel wool,nail file or very light sand paper. If nothing else possibly a loose connection where the battery attaches to the wiring
Posted on Jan 10, 2018
1 Related Answer
ray gallant
  • 68621 Answers
SOURCE: Ryobi 40volt lithium battery will not charge
then you need to buy a new one . so far they do not rebuild lithium batteries
Posted on Oct 29, 2017
Ryobi 40V 2.6A battery. When I put it on the charger the charger blinks green for about 10 minutes and then goes to solid green. However, after 5 minutes of use my Ryobi trimmer dies. I repeat the...
From your description the battery is probably faulty. If the batteries are still quite young it is possibly just one cell and while Ryobi don't refurbish batteries there are companies dotted around that do.
If it is a nicad battery, Ryobi told me just a couple of days ago they no longer supply nicad replacements and expect everyone to upgrade to lithium, which means also buying a charger.
Aug 19, 2018 | Ryobi Drills
Oct 29, 2017 | Ryobi Drills
Ryobi 40022 trimmer (40v lithium battery) has completely stopped working. Battery and charger kept inside when not in use. Battery indicates that it is fully charged when in the charger. Any ideas?
Sounds like a bad charger my friend..test suposly charged battery with a multimeter and you will find your answer...can also test charging unit with it too...GL
Aug 13, 2016 | Ryobi Garden
I purchased a Ryobi drill with Lithium batteries (Large/with gauge, small without gauge) in June 2009. The large battery lasted about 3 months and started holding less and less charge (yellow, then red on...
Batteries must be completely dead before recharging or battery life is shortened.large battery is probably defective contact Ryobi to replace battery they while probably send you new batteries for free if you tell them you are going to stop buy their products.Tell them about both batteries they will probably replace both for no charge
Jun 12, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Apr 01, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
New 18v Ryobi battery totally dead
Same Thing just happened to me, I bought a painter with two batteries. One battery did not charge. Took the kit back, got new kit. Two batteries will not charge.Charged them for additional 12 hrs, still no good. Returning them to Home Depot.
Feb 07, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Drills Logo
52 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
roeb
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
