Question about In Office Equipment & Supplies
How to format HDD in bizhub c35 - In Office Equipment & Supplies
Posted by Adeoti Akeem on
Marvin
    Top Expert:
  • In Master
  • 85,239 Answers
4 Related Answers
Anonymous
  • 24 Answers
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Posted on Jun 25, 2009
Can Guru
  • 30 Answers
SOURCE: how to change to the default from colur to black
Ok, it's been a while but here's what I remember. If your talking about default black and white COPYING, try the following. First set the machine to make B&W copies, then hit utility and go to user mode, touch current settings, then OK. B&W should now be the default.
Posted on Mar 14, 2011
Ty Schmidt
  • 118 Answers
SOURCE: SCAN TX FAILED mesasage on bizhub C35
Settings not set up properly, drop me a line i may be able to help
Posted on Oct 31, 2011
Ty Schmidt
  • 118 Answers
SOURCE: bizhub C35 Will not automatically select the #1
its probly because the tray attributes are off.. check to see if the trays have the exact attribute you are printing... if not then change them
How do i fix error code 13DD ON KONICA MINOLTA BIZHUB C35
The counter data on one card does not match counter data on a different board did some one try to reset the counters to make the machine newer???? Need to get tech out to try and rewrite the firmware,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 30, 2015 | Konica Minolta Bizhub C35 Multifunction...
Konica minolta bizhub c35 black toner being recognized as empty
sir/mam replace the cart then might have gotten a bad one from the store
Mar 11, 2014 | Konica Minolta bizhub C35 Black Toner...
Bizhub c35 new cartridge being recognized as empty
C35 error code c0203
which is it c35 or c351
Jan 10, 2014 | Konica Minolta bizhub C351 All-In-One...
Bizhub C35 misfeed error
This video will show some of the most common causes for Bizhub C35 misfeeds
https://www.youtube.com/watch?v=Sbo0gon8EIY
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_3d8ef710fe85c567
Feb 26, 2012 | Konica Minolta bizhub C351 All-In-One...
Oct 07, 2011 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Nov 21, 2008 | Konica Minolta bizhub C250 All-In-One...
364 people viewed this question
Top In Office Equipment & Supplies Experts
Marvin
Marvin
Paul Carew
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
