Question about Fisher Washing Machines
I need a replacement motor for the DCS EH-30SS (its obsolete at manufacturer). Any idea on where to buy a replacement?
The Fisher Pakel part number is 212663. So far Google, eBay & Amazon searches haven't yielded much help.
Posted by Ed Buffington on
Michael Youngman
    Sergeant:
  • 296 Answers
Take the motor to any HVAC supply house. They will be able to cross reference the motor for you with the frame number. Grainger will be able to get it also but they are expensive
Posted on Jan 12, 2018
5 Related Answers
Anonymous
SOURCE: JVC mini dv GR-D820E
i have bought the same camera and did not get any English manuel with it.
i^m lucky that i understand German but that dosen^t help as i still can^t connect my camera to my laptop even with the sugessted DV cable.
i am now thinking about bringing it back to the retailer as even by JVC.com this camera is not in the product list.
Michael
Posted on Oct 27, 2008
Anonymous
  • 145 Answers
SOURCE: How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Posted on Jan 15, 2009
Anonymous
  • 118 Answers
SOURCE: I can't find a replacement paddle.
you should find one on this site. Good Luck.
http://www.abtecparts.com/Breadman_breadmaker_paddles.htm
Posted on Jul 23, 2009
Anonymous
SOURCE: dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
Posted on Jan 21, 2010
Anonymous
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
Replaced computer in fisher and pakel top loading washer and still does not work. what is wrong??
does it beep at you? is it dead? if some lights are on while it's beeping, they are an error code, can you relay them to me?
My fisher&pakel gwl 11 wont drain/spin
Your motor controller board needs three 332k resistors replaced to make it spin again,Only on Series 11 Models
3rd 4th and 8th light + beeping every second on fisher & pakel smart drive model gw511
its one of tricky ones,because its one of two faults, both are board faults question is which one so you need two replce and try it if tht doent work replace the other one
Fisher & Pakel Washing Machine trips main circut breaker
If you reset the main breaker and tripped again then you have a shorted on the motor or on the capacitor. The motor is most likely the caused of the problem. But also to consider the wire if not contact the line 1 to line 2. Need to send to repair shop to isolate the problem. Hope that it is not your motor.
Thanks for using fixya.
My fisher pakel washer is stuck in regular wash, low water level. It sounds like the motor is emptying but it never goes to spin. I tried unplugging it to reset the computer but it always goes back to the...
Hi just just read your posting,Now have you tried selecting a different cycle and water level?Could you please confirm the model number of your machine for me.Is the machine draining the water out of the bowl? Please reply with additional information and I am sure I can help you.Looking forward to your reply.
I have a Fisher Pakel washer GWL11 and it has developed a small leak under the washer. The cycle stops at rense and just quits. Any suggestions on what needs replacing?
Sounds like it could be overfilling Just a little and while it is agitating it will be splashing over, To fix this you will need to replace the MCU,
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Electric dryer keeps tripping reset button on bottom works for about 2 load then trips it s a fisher pakel top load dryer about 4 yrs old
main drive motor problemely has dust in start switch in the motor an the motor is staying on the start cycle an not switching to the run cycle you have to take the motor apart an clean it or you may be able to air blow the dust out
Washing Machines Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
