Ec5: Overloaded or insufficient water.
1. Your load of clothes is too large. Wash smaller loads.
2. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, see #1. try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
hope this helps
SOURCE: Toshiba auto washing machine model
Hi.
E2 is not an error code. It means that the Spin only mode has been started and that the cycle is now over.
To reset the machine try disconnecting power (trip circuit breaker), connecting back, then hold down the Super Spin Dry button while you start the machine at the same time (press On while holding the other button). You should hear three beeps and the machine will be reset to initial settings.
SOURCE: I have a Toshiba Washing
aoa may machen is toshiba problem is timer not work and led blinking you gev meen anser waht porblem hai thanks
SOURCE: My washing machine modle toshiba
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
SOURCE: Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
