Question about HP Televison & Video
Why does my lorex dvr/pvr not show camera pictures on my hp monitor anymore. the monitor prompts that the display is going to sleep.
I changed the hdmi cable and checked all the other cables powered off and still can't see pictures. it was working well before i turned the system off a couple of times.
Posted by john christie on
5 Related Answers
Anonymous
  • 320 Answers
SOURCE: Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Posted on Oct 19, 2008
Anonymous
  • 40 Answers
SOURCE: No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Posted on Jul 31, 2009
Anonymous
  • 3 Answers
SOURCE: cant access lorex DVR from the internet
i have the same trouble, and i did what u said and it doesn`t work yet:S something else????
Anonymous
SOURCE: Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Posted on Jan 07, 2010
Harleen Nash
  • 1768 Answers
SOURCE: sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Posted on Feb 05, 2010
Will a HP 1740 monitor work?
you may choose another resolution in live monitor in DVR setting
Jan 21, 2016 | Zmodo 8 Channel H.264 Surveillance...
Lhv1000 DVR. Why doesn't it display anything?
Check out the video unboxing and trial setup at Lorex 8 security Camera.
Follow the hookup guide.
Make sure you have setup the mobile/Pc connectivity also.
Refer to the user manual online at https://www.lorextechnology.com/downloads/security-dvr/LHV1000/LHV1000_SERIES_MANUAL_EN_R2.pdf
Have you connected the usb mouse; TV or monitor.
Note
  • For cable runs above 300ft / 92m (option 3), you must connect the power adapter directly to the cam- era, rather than at the end of the extension cable (see diagram in page 6).
  • Indicators that your cable run may be too long:
    • Video is permanently black & white (even during day time).
    • Video is unclear, soft, or distorted.
May 09, 2015 | Lorex Home Security
Lorex eco 130 can not get to menu, screen shows Lorex page
There should be a paper clip size hole somewhere on the back of the unit. If you depress the button in there it should be the reset. The problems sounds to me more of a hard drive issue though.
Jan 17, 2015 | Lorex ECO 16Channel Security DVR with 16...
How do you monitor only 2 channels at a time on a lorex securtiy system ?
that can't be happen because all CCTV system dvr or nvr just split into 1/4/9/16 camera
Jun 13, 2014 | Lorex Home Security
Have 8 cameras, 1 is showing grey color on screen
try to plug that camera to monitor directly it can be problem with its cable or BNC connector
Jun 02, 2014 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
Lorex troubleshooting
The most common reason for loss of camera remote video is an intermittent cable connection between camera and DVR. Try monitoring with a VGA monitor, or TV with analog VGA input also to see if that is the case. Gently move the cables around that run from the cameras to the DVR while observing the multiple cameras showing on the monitor. Some remote viewing software has trouble restoring camera assignments after brief loss of camera signal.
Sep 28, 2017 | Home Security
I have a Lorex edge LH314 320GB, DVR beeps and displays HDD is not formated.
You need to format the hard drive using the built in formatting utlity. Did you replace the hard drive in the DVR maybe?
Nov 15, 2012 | Lorex EDGE L314501C4 4-Channel Network...
Sg19ld800161 CAN YOU TELL ME THE RESOLUTION ON THIS SYSTEM
Native resolution of the display is 1288 by 760. If you need to replace the monitor I can supply a list of replacements, just ask if U need.
May 03, 2011 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
Channel 3/Camera 3 not displaying properly
try swapping the cam inputs first to rule out the unit, if not the camera may be faulty or needs setting up properly with a focus adapter, or the lens could need setting up!
when CCTV company's set up these systems they have all the equipment to plug in and focus auomatically etc..
Hope this helps!
Try looking at www.digitalvideos.co.uk (test equipment) section.
Sep 22, 2009 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
Televison & Video Logo
98 people viewed this question
Top HP Televison & Video Experts
RockTheHood
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
