Question about JVC Car Audio & Video
Need wire harness for JVC KD-GS660 - JVC Car Audio & Video
Posted by Raymond Chapa on
Kev Bushell
    Habit-Forming:
    New Friend:
  • 108 Answers
Theyre pretty much universal make to make any car auto centre should have a selection at little cost
Posted on Jan 17, 2018
5 Related Answers
Anonymous
SOURCE: Install JVC Car stereo
no power
Posted on Jul 27, 2008
tripletauto
TripleTauto
  • 1450 Answers
SOURCE: JVC KD-AVX1 parking break
your car probably wont have one this wire is designed to be hooked to the park brake switch wire so you cannot watch movies going down road.as this is illegal. the wire gorunds when park brake is pressed. splice it into the wire on brake
Posted on Jan 16, 2009
Anonymous
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
Anonymous
  • 31 Answers
SOURCE: need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
Posted on Aug 16, 2009
josetejas
josetejas
  • 300 Answers
SOURCE: Just installed jvc kd-s16 and it loses power after
Connect Yellow to Battery (always 12V), red to ignition, and black to ground. Disconnect all others. Check it. If the radio stays on and plays CD, then radio is good. You may check other wiring
Posted on Jan 19, 2010
My jvc stereo will not power up but have found the black wire is live ?
hi peter, before you start using the rest of the harness cables find out if the harness you have is a jvc original for your model. the black wire is the ground/chassis cable only for a jvc kd-r411. you mite be using a compatible fitting harness whose " wire colour configuration" is incorrect for your model. cheers.
Mar 02, 2013 | JVC AM FM CD DET FACE CAR STEREO
Where can i find new wire harness?
You can obtain a new wire harness from pacparts.com. The part number is JV16-0003. You can also call them at 1-800-421-5080.
Feb 28, 2012 | JVC KD-LH3150 CD Player
Jvc kd-r200 wont power on
you have the red and yellow wire on the radio mixed up switch them
Apr 25, 2010 | JVC KD-G110 CD Player
How to install a jvc stereo kd-g230 in a chevy trailblazer 2002
First you need to get a wire harness for the Chevy (check Ebay) then follow the wiring instruction inside the package on how to join the spliced wires togother. After joining the wires togother plug the harness in and stuck the JVC into the recess where the old stereo was and thats it, it should play if not you don`t have a good ground, ground the body to the frame.
Dec 19, 2009 | JVC KD-G230 CD Player
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
I NEED A WIRING GIAGRAM BECAUSE THEIRE IS NO COLOR TO COLOR PATTERN ON BACK OF MY JVC-KD-G320
This may help your cause
http://www.nodevice.com/manual/JVC/page24.html
Jun 11, 2009 | JVC KD-G320 CD Player
Connect jvc kd-lh1150 in elantra 2001... different connector
Hello claude_bouth,You need a vehicle specific aftermarket connector generally called a "wiring harness". Your JVC came with a plug that fits the back of the receiver with "pigtail" wires which you splice to the harness wires. http://www.SonicElectronix.com sells the Metra 70-7301 which appears to be the correct harness for your Elantra.You can tap into the wiring of the car harness and splice the wires by function into the appropriate car wires, but using the aftermarket vehicle specific wiring harness is a lot easier and you don't need to disturb the vehicle wiring in any way, just plug into it. It also makes it possible to re-install the factory radio if you ever need to do so. If you choose to tap and splice, you can find your Elantra's wiring color code at http://www.modifiedlife.com.Hope this helps.
Jun 05, 2009 | JVC Arsenal KD-LH1150 CD Player
Dont have wires
I had this same problem with a sony deck. Try ebay and search wiring harnes for JVC KD-SC500.
Jun 02, 2009 | JVC KD-SC500 CD Player
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
JVC Wire Harness
If it fits it will work, If the manufacturer stays the same so does the wiring loom.
Feb 06, 2008 | JVC KD-S5050 CD Player
Car Audio & Video Logo
54 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
