SOURCE: Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
SOURCE: Brand New Paslode 900420, I bought the red gas,
Also try and check whether or not the slide where you insert the nails that you push the button down that way it is pushing the nails forward
SOURCE: will the paslode 900420 discharge two nails at the same time.
Stick with the paslode brands nails... the money you save using other brands is off-set by higher maintenance costs and tool down-time
SOURCE: paslode 900420 nailer fan keeps running
Hi, heatman101
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
SOURCE: paslode 2nd fix firing pin seems to ride over the
Ok the only thing that keeps it from riding over the top of the nail is your quick release on the front of the tool. I bet when you go to latch the front that it is not very tight. you need to replace the whole door. This should take care of you problem. # 900759 front plate assemblyhttp://www.paslode.com/cleaning-procedures.html
with them.
If
Paslode
heatman101
