When I dropped the phone in water; I grabbed it and shook it within a few seconds. But there is still a little water showing in the corners of the screen.
Hello, Christopher -
I refer you to this web page:
https://www.wikihow.com/Save-a-Wet-Cell-Phone
Follow the steps given there.
Best wishes.
Testimonial: "The web page that Jean DeLauche recommended was very helpful in solving my problem."
You can put the phone in rice it draws water out .
SOURCE: dropped in water
the water probably caused a short in the screen conector.
sorry but liquid and electronics just don't mix
SOURCE: sidekick 3 dropped in a cup of water. Water got into screen.
Is the screen blank all the time?
If you look really hard can you see the items on the screen but they are really dark? If so the back light for the lcd may have burned out.
Take a look at the following site for instructions on disassembly.
http://www.gsfx.org/disassembly/index.htm
If you feel comfortable with it, you can easily replace your own.
A new lcd runs about 50 dollars shipped. If you buy it from ebay, they
will usually come with instructions and the screwdriver you need. A T6
torx driver is the type needed.
Sidekick LCD screens
Good job on drying it out and pulling the battery. Thats the best thing you can do when you get it wet!
SOURCE: Water damage on LG 8800 venus
FILE IT AS STOLE AND YOU CAN GET A NEW ONE B/C THERE IS NO COVERAGE FOR WATER DAMAGE
SOURCE: How to dry out a cordless phone that has been dropped in water?
make sure the phone is swithced off imediatly, take out the battery or power suply, take appart the unit as much as you can and leve to dry for 24 hours underneath a lamp, do not use a hair dryer or heater as this heat will cause the cb to expand and can cause more damage, after 24 hours there wont be a prob
SOURCE: water in my zune
Turn the Zune off, then push the left and up buttons as you keep it connected to the computer charger. That will hard reset the Zune. If it doesn't respond to the hard reset it is more likely you have motherboard issue, not a screen issue. Try to clean the corroded parts on the logic board. If that doesn't help, there are parts available on ebay, there is a zune repair guide that will show you how to replace the logic board.
