Question about Polycom Lands Phones
I have a Polycom Soundstation Premier 2201-01900-001 and just over the weekend it started beeping.
Posted by Bernadette Alicea on
2 Related Answers
SOURCE: Polycom Soundstation 2 disconnects during calls
this does not appear to be the sound station problem it appears u ve connected this system behind an epabx extension .if yes the extension is programmed for a call disconnection time of 15 mins.ask ur epabx programmer to change it to infinite
Posted on Feb 08, 2009
Anonymous
  • 1049 Answers
SOURCE: Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
Posted on Oct 01, 2009
What is the ID Message on the polycom soundstation 2w
If you have Polycom Sound Station 2 and you are getting NO ID Message on screen. Please do the following:
1. Press Speaker
2. 773
This should clear up the error.
Mar 21, 2013 | Polycom SoundStation
I need to get the connector color code for a Polycom Soundstation conference phone.
From bottom of connector (not clip side)
Black
Brown
Red
Orange
Yellow
Green
Blue
White
Feb 08, 2011 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
I need the color code of the conference phone from the adapter to the phone
Does anyone have the color code to the Polycom Soundstation connector? The end fell off and I want to crimp on another.
Thank you.
Jan 28, 2011 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
What is the station type to use when hooking this polycom sound station premier EX to an Avaya S8300 on a digital port card?
The Polycon Sound Station Premier coference phone is an analog device. You need to connect it to an analog port on your phone system.
Dec 13, 2010 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Need a user Manual
here the most i can find
The SoundStation Premier and Soundstation Premier EX has been discontinued and is no longer available for purchase. Support for the product will be available until 02/21/2010.
http://www.polycom.com/global/documents/support/setup_maintenance/products/voice/soundstation_premier_user_guide.pdf
Mar 19, 2009 | Lands Phones
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Comcast Cable Modem with Polycom Soundstation Premier
Try adjusting the ringer volume, dial tone volume, and speaker volume. Make sure that the ringer type selection is not set to off. Also make sure that you are not bridging your call.
You can also use the Upgrade feature built into the phone to look for updates which may resolve your issue.
If this has only started happening recently, Restore the default settings and see if it resolves your issue.
Mar 20, 2008 | Polycom SoundStation
Lands Phones Logo
56 people viewed this question
Top Polycom Lands Phones Experts
pbxinc
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
