Tools & Hardware - Others Logo
Question about Staples Tools & Hardware - Others
I have the Swingline Optima 45. I staple once then the light blinks and I have to open where you put in the staples close it again and it will staple once. Then I have to repeat.
Posted by Scott kimball on
Alcolu John
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
Electric staplers are notoriously unreliable, but the problem you describe sounds like buildup of the adhesive -- a sort of varnish -- used to hold the staples in stick form for loading in the tool. Remove the staples and apply a light coat of 3-in-1 or other thin oil to the first two or three staples. Reload and cycle the tool. This should help you.
Posted on Jan 10, 2018
5 Related Answers
Anonymous
  • 384 Answers
SOURCE: MY SWINGLINE OPTIMA GRIP WILL STAPLE BUT THE
There is something jammed at the head of the stapler. Unjam.
Posted on Jul 14, 2009
Anonymous
SOURCE: Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
Posted on Oct 26, 2010
Anonymous
SOURCE: My Swingline Optima Power Ease
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Posted on Dec 09, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: Someone loaded regular staples into
The Optima 45 is a very touchy stapler. Either you have a staple stuck or the unit is damaged. There is a five year warranty on the stapler so if you have had under five years it will be replaced for free. Here is the contact number. 1-800-541-0094
Posted on Jul 21, 2011
Anonymous
SOURCE: How do I open the
I couldn't open my Swingline Optima model 8784x either. Their website wasn't helpful except they mention you can change staples "with the push of a button." Button, I thought. What button? In the picture, there's a black button at the back end of the stapler. Mine is missing! The button, if it were there, would press down on a metal tab, releasing the staple slide which pops out the front. Insert staples, push it closed, you're done! I used a letter opener to push down the metal tab.
Posted on Jun 11, 2012
1helpful
The auto stapling for my Optima 45 won't staple, can it be fixed? It will manual staple, but not auto. Kinda like the motion sensor went out. Any ideas??
Try to take all the staples out then put a small amount of "Two in one oil" as it is very fine oil. Once you have done this wipe off the excess oil if you have a lot spill out wipe with a rag & use the rag to wipe over the underside of one row of staples.
leave overnight & try to use this again with the slightly oiled staples this should remove any oil left then see if this does the trick. (Note I hope you have the correct staples for the machine of course.) Best Wishes Malcolm
2answers
My Optima 45 has stopped stapling. I cleared the area of crimped staples but it won't punch out a staple. What can I do?
There may be a reset button / leaver open it back up have a look around and see if there is any thing like a leaver that needs to be pushed into place for the machine to recognise it has been reset.
1helpful
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
No staples coming out of machines
The Optima line of staplers do not work without jamming continuously unless you use the Optima brand staples. They can be found in the store next to the Optima staplers in a rectangular silver box, and will solve you problem instantly. There is no other brand of staple that will work in this line (I tried numerous), but once you purchase the Optima staples, problem solved, and you'll love it!
18helpful
2answers
How do I open the swingline optima model # 8784x to reload staples?
I did not receive manual with the Optima 45 electric stapler. How do i get the slid to open to add staples?
The slide tray is on the bottom of the unit.
to open, you just press the very front button on the bottom.
it should open right up.
newimage.aspx?sku=s7048209&h=200&w=200&u=px&d=72&c=&f=jpg&char=9&p=1&o=&imageid=
Hope this helps
Good luck
Please rate FIXYA
6helpful
2answers
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
Top Staples Tools & Hardware - Others Experts
Marvin
Marvin
Jesse Walters
Jesse Walters
Paul Bade
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
