Cameras Logo
Question about Sony Cameras
How to change japan language to english on my surplus sony tv?
Japan to english settings?
Posted by jessie santos on
5 Related Answers
Anonymous
SOURCE: Chaging the language to English
turn on the camera, then go on menu right?
go to setup, then scroll down until you see language on the right side.then click on the right arrow (to highlight 'language'),and click on in once again to change te language, click on english, and wahhla!9 oh, and i 'think' click on ok after that. :)
Posted on Apr 06, 2008
Anonymous
  • 34 Answers
SOURCE: LANGUAGE SETTING JAPANESE TO ENGLISH
Hello analyn
There may be a simple fix to this problem.
Find a friend that has a cybershot of the same model as your own. In their camera, open the menu and navigate to the language setting. While you do this count how many times you press the button. Example:
Menu
-camera settings 1
-program 2
-personal settings 3 press ok
personal settings
-storage type 1
-date and time 2
-language 3 press ok
language
-spanish 1
-english 2 press ok
-japanese
Although the language is different, the number of spaces should be the same, so even though you can't read it to change the language, you should be able to count it out. Or if you are lucky you may have a Japanese friend who can read it.
Hope this helps
-Chris
Posted on May 01, 2009
Anonymous
SOURCE: how do i change the language of clarion from japan
i want to change languade from japan to english
Posted on Nov 26, 2010
Anonymous
  • 1177 Answers
SOURCE: My question: I bout a
The language setting is the last option on the setup menu. Press menu, then right side of the rocker for setup, then up for language, then right to set and up or down to select English, then menu to exit.
Posted on Jan 27, 2011
Anonymous
  • 300 Answers
SOURCE: change language from japanese to english
The region has to be changed to US or UK. It is done with a special Sony adjustment software.
Posted on Mar 05, 2011
2answers
Kenwood mdv-727dt change from japan to English
car came with this new,??? or not?
if yes did ask the car dealer first.
if not ask Kenwood. this, some cannot be changed, warning!!!
depends on exact model sub codes
KENWOOD MDV 727DT MDV 626??? youtube it and many ask there, but on answers but this.
learn to google and youtube.
learn that non japan exports of NAV box do not have language sets.
yes there are 3 kinds, Universal, japan only or some other language only models.
https://youtu.be/pSdgDYjApdM
if the button seen hit above is missing that means Japan only model.
Unfortunately, the language is set in the firmware and cannot be changed. So, to change the language requires that the unit itself be replaced. I wish I had better news for you but that's is the way these systems are distributed.
if the language menu is missing there.
There are very few Kenwood Units that have the ability to change Language, and I do not see the MDV-727DT as being one of them.
How to change japan language to english settings on my sony surplus tv?
If it came from Japan as domestic use only, it may not be possible.
I have clarion max685 touch car tv , how to I change japan language to English language
Japan language?
Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
1helpful
2answers
How to change language for HDR CX560V Japan from basic Japan to English
I have compared its instruction manual in English and Japanese versions and found that the language setting part is absent in Japanese version. So that the japanese version will support only japanese.
I have asked the seller in Bic Camera shop (in Japan) and he tried to change the language in the menu, but unfortunately he could't find and change it.
I need to change languale japan to english rom japan
HI there if you don't know Japanese language then you no able to change that in English. For this you need to use some tricks. If you have Manual then open the manual and follow the steps for going in location for setting. if you manual is in Japaneses language then download manual from Net then try. Thanks.
25helpful
3answers
How to switch language on japanese bought sony dsc-wx1 cybershot?
I bought a camera in Japan (Sony Cybershot DSC-WX1) and now it seems that i can't change the language from japanese to english. If i select (can't read it but with the help of the english digital guide i think i have the right menu)change language, there seems to be only one language available. -japanese- How do I solve this?
26helpful
2answers
Japan languange in cmos
The "default" BIOS-settings should be used.
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
