Question about Kohler Electrical Supplies
I have a Kohler 17RES Generator with an F 1 code what is that code ?
Posted by Rogue Jesse on
BrianHaze
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
Check the f1 fuse.
Posted on Apr 16, 2019
4 Related Answers
Anonymous
  • 5 Answers
SOURCE: My Kohler 17RES has stopped doing it's scheduled
On your Automatic Transfer Switch ( the little gray box you see on the right in the picture above) you have two blue buttons. One is a Manual test switch. The other has a clock on it and this is your exercise set button. Hold it down for a FULL 3 seconds if you want it to excercise without a load (not powering your home) Hold it down for a FULL 6 seconds if you want it to exercise with a load every week. Your generator will start and run for 20 minutes, and then shut down. Now every week your generator will exercise at the time and day that you pushed the set button.
Posted on Sep 04, 2009
SOURCE: My Kohler Model 17RES threw
The chattering sound is the stepper motor trying to cycle. Check to make sure there is no interference, move the throttle linkage by hand back and forth fully as sometimes the 17, 18, and 20 butterfly valve sticks on the carburetor gasket. If this happens, remove the gasket and use a file to put a good bevel (45 degree angle) in it to stop it from hitting. Thats all it takes.
Posted on Sep 06, 2011
Wayne Holden
  • 512 Answers
SOURCE: Kohler 30RZ62 generator Parts
You are going to have to register with Kohler and use this site to get your part:http://www.kohlerpower.com/residential/sectionfront.htm?sectionNumber=13561
Posted on Oct 08, 2012
Wayne Holden
  • 512 Answers
SOURCE: What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Problem solved by poster. good work!
Gen runs when switch in auto even though power avail. Tried resetting ATS - waited 30 min. No luck. Only way to turn off is to move switch to stop/reset. Any ideas on what is broken?
have an electrician check the relay that is activated when the utility power fails
that is what starts the genset when it is in auto
it should also stop the get set when utility power comes back on
Nov 03, 2015 | Kohler 17RES 17 kW Generator
Where is the speed sensor located on a 20resa kohler genset
Kohler Generator issue 20 RES - YouTube
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
May 19, 2015 | Kohler 20resa 20kw Home Emergency Backup...
Generator code 0094 01
Can you be more specific? what model Kohler is it, Model number KW etc.
Sep 15, 2013 | Kohler Electrical Supplies
My Kohler Model 17RES threw an Overspeed Shutdown code. I have been unable to reset the system. It makes a short "chattering" sound around the circuit board area when I try to manually switch the...
Jul 23, 2011 | Kohler 12 kW Emergency Power System -...
17 KW Kohler will start and idle but will not step up to proper RPM to run the generator. Is it common for NO gas (Propane) pressure to pass through the regulator when the engine is trying to start. Or...
i think the propane regulator is controlled by engine vacuum pressure in a lot of gensets. when was the last time your valve clearances were checked? this is just a thought because if the valves are too tight it may not make the vacuum needed to open the regulator. not sure but its easy to check.
Jul 08, 2017 | Kohler 17 kW Emergency Power System -...
Hello..problem to my kholer 17res generator is that it is starting normally,but suddenly it changes its voices like much louder then its normal voice and shut down..it work fine for 2 years,i am facing...
hi
there are number of factors to your problems in this instant might be wise to get an assessment carried out by an engineer before incurring further and costly repairs
Dec 10, 2017 | Kohler 17 kW Emergency Power System -...
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
My Kohler 17RES has stopped doing it's scheduled weekly exercise. How can I get it exercising again?
Aug 08, 2009 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
214 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
