Unplug your TV hold the power button down on the TV itself for one minutes release the power button plug it back in and turn it on yeah power build up and not yet overpowering of the power supplies you probably have it on power bar not plugged directly into the wall post TV to be plugged directly into the wall the wise Yup Yup mismatched power
Testimonial: "No didn't work green lines on screen again thanks"
SOURCE: 12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged
into both AC and DC at the same time. The Engel is smart enough to use
the AC while available and then automatically switch to DC when the AC
is no longer working. It will also sense the resumption of AC power and
automatically switch back to AC making it ideal for high hurricane areas
and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
SOURCE: When I turn on the tv I am only getting the the
Do a hard reset to this TV and check. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
SOURCE: My SONIQ FLATSCREEN MODEL E32W13D-AU HAS STOPPED WORKING BUT STANDBY LIGHT IS ON??
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
