Question about Koss Audio Players & Recorders
I dont get anything out of the speakers, wow do wire up a Koss ModelKs5192
Posted by Rick Miller on
1 Related Answer
Open SKy
Carlos L. Burgos
  • 620 Answers
SOURCE: Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
Posted on Oct 17, 2008
1helpful
Left speaker on my Koss SB45 Headset isn't working unless I tilt to the right or turn around.
Have a look at my tip on headphone problems. Just click my user name to find it.
3helpful
3answers
What voltage are the koss 'older' computer/CD speakers that would take 3 'C' batteries each. I have a variable voltage adapter and am not sure if I should switch it to 9 volt or another setting for AC...
C cells are 1.5 volts each. If the speakers use three of them that means you'll need a 4.5 volt supply. If each speaker needs batteries, you'll need to feed that voltage to each speaker, and the supply should have enough current for the total load. A 1-amp rating is probably fine.
1helpful
For the third time - wesite headphone speakers!
Have you tried asking here yet:http://www.koss.com/koss/kossweb.nsf/cs-contact
2answers
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Left speaker doesn't work
Koss has a no questions asked guarantee on some of the Pro-4 series, all you pay is shipping. Call the repair department to check.
Repairing crossover
I have the Koss-original wiring diagram for the CM/1030 - both the "old" and "new" versions. Contact me at [email protected]. Jeff Mackwood
Hello there! lellya
First,
good luck
Koss KS3102 System
I had a similar problem. Believe it or not, I randomly switched which ports the speaker wires used to connect to the receiver and kept playing with it with music going until all the speakers were making noise.
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Marvin
Marvin
 Grubhead
Grubhead
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
