Question about Bosch Tools & Hardware - Others
Replacing the battery on bosch prio sander - Bosch Tools & Hardware - Others
Posted by Leonidas Bachas on
tip
Replace drive belt Bosch pbs7a
To replace drive belt on Bosch 7 PBS belt sander remove cover, 3 screws, place new drive belt over splined drive pulley. Feed belt clockwise over paper pully and Utilize welded hexigonal with suitable wrench to turn and 'pop' the belt on.
NEED A AUTO REPAIR SHOP TO RESET IT ONLY THERE COMPUTER CAN DO IT OK
Bosch Prio Sander failure
The screeching was indeed the sound of a bearing seizing, however now that the motor is running freely it means the bearing is in fact seized and burned up the plastic that holds orbital mechanism. Its possible to diy, you'll have to open it up to see what damages that bearing created. Hopefully you still have a warranty...
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
1helpful
2answers
Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
CLEANING SANDER BUSHINGS
It's usually not the brushes but the commutator that needs cleaned. The commutator is the surface the brushes ride on. Go to Walgreens and buy a multi-surface nail file, one of the soft ones that are about 3/4" square with different colors for different grits. Don't start at the coarse grit!! Start at the medium grit and lightly drag it over each section in a smooth arcing motion, when the commutator surface is shiny it's clean, then replace the brushes with new ones.
Tools & Hardware - Others Logo
Top Bosch Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
