Question about Crosley Washing Machines
How to reset my Crosley washer? The lights won’t come on. What can I do to fix it?
Posted by Kayla Bodiford on
Rick McAlister
    New Friend:
To reset your washer hold the start button for about ten minutes.
Posted on May 30, 2019
Peggy Hill
I have a Conservator washing machine and the lid lock light flashes and can't start
Posted on Sep 24, 2018
Eric Sutherland
    Master:
  • 665 Answers
Spin light is blinking on my crosley washer
check belt is not Brocken filter is cleaned also can be the motor not turning check brushes or that the motor is not burned
Aug 13, 2014 | Crosley caw9244xq 3.4 cubic foot white...
Washing machine control light is on and it won't start, what can I do to fix this?
You could try a reset by unplugging the cord, wait 10 minutes or more, then plug it back in and press the Start/Cancel button.
Otherwise, if a chinese control board is bad, you'll need a technician.
May 25, 2014 | Crosley Washing Machines
Crosley 5000 front load washer won't spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with either the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 24, 2012 | Crosley Washing Machines
Crosley CAWC529PQ1 won't turn on.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
Nov 25, 2012 | Crosley CCW5294W Top Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Crosley 1244 washer won't cycle
This indicates a faulty lid switch.
Apr 27, 2012 | Crosley Washing Machines
Crosley washer cfw8000gw wont drain. checked filter, it is clean. now what?
go to the appliancerepairplanet.vstore.ca and get the manual on this and it can help u fix this
Dec 01, 2010 | Crosley CW5000 Front Load Washer
Washing Machines Logo
1,396 people viewed this question
Top Crosley Washing Machines Experts
peter gittos
peter gittos
Michael Thomas
Michael Thomas
Lawrence Oravetz
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
