Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
SOURCE: cant programme Phill Jumbo Universal remote controller
it would take a week to type the book and code's.
best bet> forget the jumbo bit.google universal remote control. they are all much of a much and get info from any
SOURCE: Need code to program universal remote for my Apex LCD TV
i have apex tv 2003 and i need a code for my remote
